Old 11-04-2010, 07:20 AM   #31 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by Braebyrn View Post
Well about the only thing to fill in the gap on my setup is to put a flexiable connection between the truck and the trailer. Something that is on springs or maybe surgical tubing imbedded in a vinyl wrap. That way there is no drag behind the truck.
I tend to drive 64 at the most even when the speed limit is 75. Seems to get the best right around 60-64 now with the new parts I put on the truck.
Funny thing is when just driving the truck, I am getting around 21mpg on the highway at 60. Thats with the air dam, side skirts and mods on the bumper and grill area.
A hit from 21 w/o trailer to 12 w/ is a LOT of loss. Are you in a hurry? If not there should by all rights be further room for improvement w/ driving habits alone. Combine those with aero mods for the ultimate. :thumb
Good luck!
KB
Old 11-04-2010, 09:49 AM   #32 (permalink)
seeking aero mods
Good luck!
KB
I have always pulled with a open trailer until recently and got around 15 at 60 to 65mph. Hook up the enclosed and its really like pulling a brick wall! I am going to bring the trailer in to the mfg to check for the wheel alignment, dragging brakes, etc.
The truck has just had a front end alignment and the brakes checked for draging which was fine. Also, since it gets the best fuel mileage now ever without the trailer, I tend to think now its got to be the trailer.
I just drove from Seattle to Austin, TX and back and was not in a hurry. This is without the nosecone, but with the airdam , side skirts and mods to the grill opening area.
From Texas to WA
11.4 mpg 60mph
9.9 mpg 60 mph
8.9 mpg 60 mph
9.8 mpg 55 mph and into headwind
11. mpg 60 mph
9.9 mpg 60 mph
10.2 mpg 60 mph
9.3 mpg 60 mph
10.3 mpg 60mph and into headwind
8.7 mpg 60 mph and into headwind
9.3 mpg 60 mph and into headwind
8.6 mpg 60 mph
9.1 mpg 60 mph
9.6 mpg 60 mph
8.2 mpg 60 mph
9.6 average mpg. No nose cone, no boat tail, only airdam, side skirts and mods to the front bumper area. It seems to me that with the mods only to the truck, the aero drag got worse in the back? Does that make sense?
Old 11-04-2010, 06:50 PM   #33 (permalink)
Recreation Engineer
KamperBob's Avatar
Dropping from 21 w/o trailer to 15 w/ seems like a big hit to me, especially for an open trailer. I'd still obsess over driving habits. Set the ScanGauge on Current MPG mode. Then it's a game. Go for high score. If it's not possible to improve, maybe the truck isn't a "great" tug. (shrug)
Good luck!
KB
Old 11-04-2010, 07:15 PM   #34 (permalink)
21 to 15 towing sounds about right. My F150 goes from 18-19 to 13 or so pulling a big heavy flatbed. It does take more fuel to do more work.
Old 11-05-2010, 02:34 PM   #35 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Keep it simple.
Add a deflector wing on top of the truck.
They work better on 5ths but can help on TTs.
The good ones / homebrews fold flat when the trailer is off.
I am working on one that goes negative for a sort of kamm effect.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 11-06-2010, 04:21 AM   #36 (permalink)
seeking aero mods
Well a friend and I made a new boat tail setup. It has a welded frame and pivots on hinges. I tested it for about 25 miles and came up with 3 to 4 mpg increase, but the long drive is coming up for the real test. I'll post some pictures in the next couple of days.
The Following 2 Users Say Thank You to Braebyrn For This Useful Post:
aerohead (11-06-2010), slowmover (11-07-2010)
Old 11-06-2010, 07:25 PM   #37 (permalink)
Recreation Engineer
KamperBob's Avatar
Looking forward to the new tail and report.
KB
Old 11-07-2010, 08:55 AM   #38 (permalink)
seeking aero mods
Ok, I put 550 miles on since it was built. Driving 60 mph, I am getting a solid 2.5 miles per gallon increase. I havent yet been able to drive on level ground, but that is coming today.
Name:	gmc boattail.jpg
slowmover (11-17-2010), Weather Spotter (11-08-2010)
Old 11-07-2010, 10:01 AM   #39 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Beautiful !
( I can't see any plates though. )
Old 11-07-2010, 10:45 AM   #40 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Hey Phil, what's your opinion on adding some small trip strips along the sides of the tail where it has excessive curvature ? I'm guessing that due to the excess curvature on the sides, the flow is separating and going turbulent. If trip strips were added, it would keep the flow nice and tidy, but by still leaving the tail the length that it is, much of the wake could be filled in.
Tractor Trailer Boat tail trikkonceptz Aerodynamics 26 01-07-2025 03:18 PM
One wheel trailer as an aero mod?? Vwbeamer Aerodynamics 27 01-20-2021 12:37 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
