Old 02-01-2015, 12:28 AM   #11 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Here's my take on it using the AST2 overlayed on a good perspective shot of a 2010 Prius.
It shows about a 2 1/2" to 3" diversion at the spoiler from ideal. I really don't think it'd make a significant difference if you were to just add on to the rear and sort of split the remaining line to try and match ideal.
High Res Version of Above Pic
Like this.
Higher Res Version of Above
The Following User Says Thank You to ChazInMT For This Useful Post:
Rishar (02-01-2015)
Old 02-01-2015, 12:57 AM   #12 (permalink)
Aero Deshi
ChazInMT's Avatar
And here is a trace of the above over your PhotoChops
HighResVersion
Looks to me like if you just raised the tail lights of your shorter version by 3", you'd be very close to ideal.
Pay no mind to my diffuser area, I didn't give it much thought, but yours does seem a bit too steep, mine may be too shallow.
Rishar (02-01-2015)
Old 02-01-2015, 02:02 AM   #13 (permalink)
What did I just do?!
Rishar's Avatar
Angry Bird - '10 Toyota Prius
90 day: 62.27 mpg (US)
Originally Posted by Vman455 View Post
Tuft test it first, otherwise you're just guessing what the airflow is doing now. I'm betting you'll find there's attached flow all the way down the back.
I had done a tuft test and you are correct, it was attached all the way down. It's why I initially went with the idea of just continuing the current contour of the Prius. (well, that and ease of build)
Aww, and here I liked my photochops...I'd never messed with that program before so I admit I got a little carried away :P
As for the diffuser area, I just moved the template overlay up so that it matched the bottom of the bumper. Seemed like an appropriate way to do it.
Old 02-01-2015, 03:08 PM   #14 (permalink)
Thee Template is more or less a guideline, as it assumes a half-circular cross-section. Taper in plan and tumblehome affect the result (see the GM EV-1). You can't even trust tufts completely, but Toyota seem to know what they're doing.
Old 02-01-2015, 03:45 PM   #15 (permalink)
Strangely, the most relevant result for "prius wind tunnel" was:
Would the smoke have stayed tighter had the taper been slower?
Old 02-01-2015, 04:23 PM   #16 (permalink)
Rishar's Avatar
It almost sounds like a case of you can study, learn, and put it down on paper all you want, but you won't know until you do it and see what happens using the best guesstimate you can. XD
At least, until there is a publicly available wind tunnel.
Old 02-01-2015, 07:28 PM   #17 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
There are some...but they're $$$.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 02-01-2015, 07:51 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
The A2 wind tunnel is quite reasonable for what it is. : A2 Wind Tunnel
Old 02-01-2015, 08:07 PM   #19 (permalink)
That might be, as Aerohead explains, simply a compromise for functionality. The angle seemed to match to me.
Old 02-01-2015, 08:55 PM   #20 (permalink)
Rishar's Avatar
I need to find a decent cheap matchbox Prius and mod that first >.< lol
