Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old Today, 12:41 PM   #241 (permalink)
' tired old engine... fixed '
* I'm not going to marginalize what you experienced, or any of the other contributors here at 'BORPower', but, at the time you originally posted about nBA, I was already familiar with 'explanations' about turning worn-out engines around, which did not require invoking 'boric acid'.
The same 'explanation' was hiding in plain view in basically every 'engine treatment' manufacturer's literature.
Hence the 'deep-dive' into the past.
Old Today, 01:14 PM   #242 (permalink)
' engine wear '
1) The engine manufacturer is only accountable to the 'car' buyer for the duration of the new car warranty ( presently Hyundai/KIA/Genesis offer a 10-year or 100,000-mile warranty.
2) Caterpillar Corporation studies there engine design within the context of, 10,000,000 miles duty cycle, over 7-8-years, with 25% 'wear' over that time span, before 'overhaul'.
3) My 1984 HONDA CIVIC CRX was at 337,000-miles when I 'parked it', in perfectly-running condition.
4) My 1994 Toyota T-100 pickup, with the 2.7-liter, inline 4-cylinder, is running well at 447,000-miles on the odometer ( I believe member BamZipPow's T-100 has more mileage than mine ) just changing the oil & filter at 7,500-miles.The rubber valve-cover gasket became very brittle and I replaced it, but the engine is basically 'un-touched.'
5) So, I'm curious as to these 'worn-out' cars, and how that's 'quantified'?
It seems like Toyota will do 1,000,000 miles ( 1,609,357- km ). What do people expect?
Old Today, 01:33 PM   #243 (permalink)
' 20,000-km between oil & filter changes '
1) I visited motor oils the other day.
2) Cars that MotorSilk marketed to were using API SD oils.
3) Today, we're up to API SP oils, with viscosity as low as 0W-8 ( Mobil I, 100% Synthetic, designed for hybrid cars requiring SAE 0W- 8)
4) Mobil Corporation is recommending the oil & filter change @ 10,000-miles.
5) A 20,000-km oil & filter change interval exceeds Mobil Corporation's interval by 24%, and we're talking about a motor oil approved in 'supercars.'
6) I may be wrong about the 'discoloration', but I'll ask local dealerships for samples of warranty car oil drained @ 10,000-miles to have a 'look' ( I've never seen used motor that wasn't discolored, in 68-years ).
Old Today, 02:02 PM   #244 (permalink)
' don't test it '
1) All I said was that, there is no 'scientific method' to any of the 'tests', leaving us no real actionable information.
2) When I asked you directly to provide more specific information about your 'test' experience you purposely withheld the information from me, which might have given any of us 'non-averse-to-mathematics' members ( some retired automotive engineers ) a possible way to cast more light on member experiences, which in 'science' , is typically a 'GOOD' thing.
3) According to President Abraham Lincoln, for you to 'know' and not 'tell' makes you a 'coward.'
4) No API, ASTM, or SAE automotive engine tests are conducted on 'worn-out' engines, so we have nothing 'scientific' to help us understand the nBA phenomena.
5) Dr. Erdemir never tested any Boron substance with 85% the hardness of diamond.
5) He never demonstrated a 1,000% friction reduction.
6) The 'research tribologists' talk about Reynolds number effects all throughout their reporting, but you fail to 'see' any of it, as they're writing to a technical audience who will pick up on it by default.
I'm out of time, I may come back later and pick up on the thread.
Old Today, 04:10 PM   #245 (permalink)
' Erdemir's passenger car numerical representation metrics '
Here are the values used by Argonne's tribologists to provide context to their conclusions.
If your car is exactly as described, then you have the highest probability to see numbers as predicted/observed. And bear in mind that this data is 13-years old, and the cars were manufactured 25-years ago.
https://www.sciencedirect.com/scienc...01679X11003501
Old Today, 04:45 PM   #246 (permalink)
viscosimeter arrived
Color Service left a message that they had the unit.
Made by SATA, Germany.
$92.00 ( US ) after Governor Abbott stuck his hand down my pants.
The Saybolt Universal Second units can be directly converted into CentiStoke ( cSt) for SAE viscosity comparisons at the reported global, standardized test temperatures.
There exist no direct viscosity conversions for static / dynamic 'friction coefficients.'
For automobile lubrication, 'viscosity' is the most important metric for an engine's health, and what the additive package is designed around.
