Old 02-14-2021, 11:13 AM   #1071 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Probably buy the V nose, because you're going to be building either way, and it's got more volume.
New is, as you said, faster. You'll also have a better shell, factory-made doors, etc, and you'll still have your utility trailer.
Transmission type Efficiency
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
Hersbird (02-14-2021), Xist (02-16-2021)
Old 02-14-2021, 09:14 PM   #1072 (permalink)
What would you do?
I would be tempted to try making a teardrop trailer with some slide-out sections
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
Hersbird (02-15-2021), Isaac Zachary (02-15-2021)
Old 02-15-2021, 01:42 AM   #1073 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Ditto on the tear drop trailer.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
Old 02-15-2021, 03:43 AM   #1074 (permalink)
In 2015 the prevailing wisdom was the slope shouldn't exceed 22 1/2 degrees.
Old 02-15-2021, 08:14 PM   #1075 (permalink)
Dark Egg - '12 VW Touraeg
I'm not to concerned with economy on this build, the Jeep sucks gas anyway, I've been averaging under 12 mpg but it would be bad to drop that as low as 8 or something. While I could see making a 300 mile highway trip and then going slowly 20 miles off into the boonies on dirt roads, most trips would be 30-60 miles of highway and then slow up into the mountains. Those mountain roads would be 30 mph tops, maybe lots of 3 mph.
Now a teardrop highway camper would be the bomb behind the TDI Touareg as it already gets about 30 mpg on the highway. Then I could do long trips to the coast and down to the redwoods with it. Or maybe the Grand Canyon.
I may have to do both!
Old 02-15-2021, 08:16 PM   #1076 (permalink)
Another advantage of the v nose is that extra 2' may make the 10' kayaks just fit inside stacked but I'd have to measure closely.
Old 02-16-2021, 03:23 PM   #1077 (permalink)
I'm not to concerned with economy...
Odd thing to post on Ecomodder...
Old 02-16-2021, 05:06 PM   #1078 (permalink)
To/two/too conflation isn't that uncommon.
Fat Charlie (02-17-2021), Hersbird (02-17-2021), Isaac Zachary (02-16-2021)
Old 02-16-2021, 07:46 PM   #1079 (permalink)
Maybe something like this instead of slide outs.
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
freebeard (02-16-2021)
Old 02-16-2021, 09:38 PM   #1080 (permalink)
Needs a shark-mouth.
pickup, trailer
