Old 02-21-2009, 05:21 PM   #1 (permalink)
Canadian MPGuino for kilometers
I've modified 0.75 to select US or metric units at compile time.
Eventually I'd like to be able to switch units on the fly or at least select USA/Metric in the configuration and I've started coding in that style, but there wasn't enough program memory on my first attempt.
Updated June 12, 2009: it works on my 95 Neon Sport, 2.0L SOHC, 5MT - VSS/KM=9926, MICROSECONDS/LITRE=57442679.
I'm working on version 76m using the Atmel328 and Arduino IDE 0013 - plenty of space now - have already added RPM and working on L/KM.
Thanks everybody for this most excellent project. Being relatively new at Arduino, it is good to see more advanced code samples using interrupts/etc.
The Following User Says Thank You to mluckham For This Useful Post:
alvin_wj (05-30-2013)
Old 03-08-2009, 10:38 AM   #2 (permalink)
Thanks, I myself gonna convert units for a while but i'm just too lazy to start. I think this must be included in wiki.
Old 03-10-2009, 09:08 AM   #3 (permalink)
Ziggy - '95 Audi S6 Sedan
Manfred - '97 Audi A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 Audi A4 Quattro Avant
Sherman - '98 Audi A6 Quattro Avant
Cab - '96 Audi Cabriolet
Well done!
The runtime switch will be difficult if you don't want to reset the MPGuino but just switch the current information from gallons/miles to liters/km or vice versa. It's possible but would require conversion functions everywhere that the units are used. I suppose the data could be kept internally in some arbitrary units and then always converted for display.
I gave up trying to work within the ATmega168 Flash constraints. I'm using an ATmega328 with Arduino-0013. Works just fine and cost $5.00US for the chip.
Old 03-10-2009, 10:31 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Just FYI, here is a mega88 (half the flash of a 168), lot of work but can do a lot with not much:
I'm working on metric and pulse direction for the 168 cuz there are a lot of 168s out there. Might come down to a "bootloader not installed" compiler flag though.
Old 08-03-2009, 01:12 PM   #5 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Thumbs up MPGuino Metric
Thank you very much!
By the way, what does 0.75 mean or state for?
Thanks again,
Old Beaver
Old 08-08-2009, 08:10 AM   #6 (permalink)
AlainB7's Avatar
instead of km/l, it will be good to have a l/100km display.
Old 09-10-2009, 07:49 AM   #7 (permalink)
Smile Honda Civic LX 1999 metric
Hi,
Thanks to DCB for this great project and Mluckham for the metric conversion. I've built the MPGuino using an iDuino kit, everything went smoothly, installed it on my Honda Civic LX 1999, it's working great! http://forum.ecomodder.com/images/smilies/smile.gif
I'm still in the ballpark about VSS p/km (currently 5100, I estimate it is no more than 10% in error) and uSec/km (using 0087696156 guess it is showing consumption 10 to 20% better than it really is...), need more time and fillups to calibrate better.
The Following User Says Thank You to demarco For This Useful Post:
mgiraldelli (10-29-2009)
Old 09-12-2009, 04:32 PM   #8 (permalink)
MPGuino metric by Demarco
Hello Demerco!
Nice picture! Congratulations for your work!
I haven´t been able to attach my MPguino to my diesel car yet.
Can you tell me the nature of the vss signal the MPguino wants to receive?
Well, I know it is a digital signal, but, what else?
I have a diesel car with two fuel flow sensors which send a digital signal each.
Computing the difference I have the actual fuel consumption.
Do you figure where can I input this fuel consumption signal to MPGuino as to be understood as real time fuel consumption?
Somewhere in the program, the vss signal si converted to fuel consumption, isn´t it?
Can you help me to identify the program sequence where that variable is inputted?
Thank you much,
OldBeaver
Old 09-13-2009, 07:11 PM   #9 (permalink)
Hello Oldbeaver,
Thanks for the compliments.
My car runs on gas, I don't know how to connect a MPGuino to a diesel car.
About the VSS signals, I suppose they are pulses of 12V and the AVR microprocessor counts how many pulses, each pulse corresponding to a certain distance travelled.
If the motor doesn't have injectors from where to obtain the fuel flow data, instead it has two different fuel flow sensors which requires an arithmetic operation, then I guess MPGuino would need another input and a new software.
I'm a newcomer to microprocessors and I'm not able to help you with program modifications, sorry!
Gud luck,
demarco
Old 09-14-2009, 12:00 PM   #10 (permalink)
Ok to all.
Well, I am not an expert myself. But what you said gave me a idea, that I will test.
Maybe I just need a constant to convert my pulses into MPguino like pulses.
Vocé fala Portugués?
OldBeaver
0.75, canada, canadian, kilometers, metric
just some humour for my Canadian freinds metroschultz The Lounge 6 12-23-2008 10:10 AM
News: Toyota unveils production version of Smart car competitor MetroMPG General Efficiency Discussion 8 09-06-2008 12:58 AM
Which Version of the Metro was most Fuel Efficient? Wayneburg General Efficiency Discussion 4 05-02-2008 07:10 PM
Canadian government caves in to automakers and kills auto efficiency rebate program MetroMPG General Efficiency Discussion 12 04-01-2008 06:19 PM
Canadian feds moving to block NEV's from public roads (also: hilarious ZENN vid) MetroMPG Fossil Fuel Free 11 12-20-2007 09:07 AM
