Old 01-01-2013, 10:29 AM   #111 (permalink)
Not Ordinary Engineering
Hey guys, I see some of you are concerned about digitally finding your frontal area and looking up your Cd values so you can calculate your CdA but why?
CdA is what we call Flat plate Drag (FPD) in the field. FPD is simple to use and is the coefficient needed to calculate drag (or vise versa in our situation). It produces easy to compare values for your baseline and modification data.
Flat Plate Drag uses the same equation we are already familiar with:
Drag = 0.5*density*velocity^2*FPD
(honestly, what it does is set Cd to 1.0 to remove it from the equation, then your comparisons are in fictional areas with a Cd of 1.0)
Do you guys have a test methodology for determining drag?
Is there a standard for testing yet? Is that something I could help put together?
-Ryan
The Following User Says Thank You to ryannoe For This Useful Post:
aerohead (12-09-2021)
Old 02-21-2013, 03:11 PM   #112 (permalink)
Blue Angel's Avatar
Previous Car - '12 Chevrolet Cruze Eco MT
Team Chevy
90 day: 44.29 mpg (US)
535d XDrive - '16 BMW 535d M-Sport
Hi all, first post here. I have a '12 Chevy Cruze Eco MT and so far I am very impressed with the mileage as well as the car. For a car used ~95% for commuting it is really working out well.
I looked through your list here and didn't see any info for the Cruze so I thought I'd make a contribution:
Width = 1796mm/70.7in
Height = 1476mm/58.1in
Height = 1466mm/57.7in (Eco/RS*)
Cd = 0.331**
Cd = 0.298 (Eco)
Doing the math I get a CdA of 7.649 for the standard Cruze, and 6.839 for the Eco.
*- Eco height is standard car height -10mm; I couldn't find a spec for the Eco height but it uses the RS package springs making it 0.4in/10mm lower than the standard car.
**- Eco Cd is 0.298, according to GM this is a 10% improvement over the regular Cruze, so 0.298/0.9 = 0.331
EDIT: Added 0.81 correction factor to calculations
Last edited by Blue Angel; 02-21-2013 at 03:19 PM.. Reason: Added 0.81 factor to FA
The Following User Says Thank You to Blue Angel For This Useful Post:
aerohead (02-23-2013)
Old 03-07-2013, 01:57 PM   #113 (permalink)
The VW XL1 frontal area is 1.50 sq m which is 16.146 sq ft. The Cd is 0.189, so the CdA is just 3.05 sq ft.
aerohead (08-06-2016)
Old 04-02-2013, 02:45 AM   #114 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Is this mentioned already?
Ilmanvastuskertoimia
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 3 Users Say Thank You to Vekke For This Useful Post:
aerohead (05-28-2014), Piwoslaw (04-04-2013), renault_megane_dci (08-09-2013)
Old 04-03-2013, 05:24 PM   #115 (permalink)
flat plate drag coefficient
-Ryan
Road vehicle coefficients of aerodynamic drag,as a convention,are always presented as pertaining to frontal projected area.
If we know the original Cd,if only the shape of the vehicle is modified,and a change in mpg shows up,there is a metric by which we can reverse-engineer the new Cd.
The best method to measure drag will remain the full-scale wind tunnel.At $435-$2,000 an hour,they're kind of pricey (and if you can book time in one).
Coast-down testing is so problematic,that while not 'impossible' to pull off,most auto makers have gone to the wind tunnel for results instead.
Computational Fluid Dynamics,while better than ever,is so expensive that it remains within the domain of universities and auto makers.
Old 04-04-2013, 07:22 AM   #116 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
VW up!
Cd = 0.32
Frontal area = 22.28 sq.ft.
CdA = 7,13
That's not too bad for such a small car - 3.54m or just under 12 ft.
The Following User Says Thank You to euromodder For This Useful Post:
Old 04-04-2013, 05:44 PM   #117 (permalink)
GeekForLife's Avatar
White Elephant - '07 Toyota Tundra SR5
90 day: 19.27 mpg (US)
Raberta RX - '14 Lexus RX350 Base
Either I am misunderstanding the formula or the numbers on the chart are wrong.
Someone check my math here I may be suffering from slept through math-atitis
The first car on the list
Acura CL 1997-1999 Height = 54.7 Width = 70.1
frontal area = 21.6 ft^2
My math
54.7*70.1*.84/144=22.37 ft^2
Am I daft or is the page wrong????
Old 04-13-2013, 06:13 PM   #118 (permalink)
Slow steppin'
Coroner's Avatar
2013 Coachman 21QBC - '12 Chevy Express 4500 RV
2011 Kia Forte Hatchback:
cd: .29 - Edmunds
Height: 57.5"
Width: 69.9"
Frontal Area: 23.45 sq ft (includes .84 correction)
cdA: 6.8009
I didn't see any Kia's, so here's one.
If you pay for my gas, I'll go faster...
I brake for tailgaters...
Poop management professional, it seems...
The Following User Says Thank You to Coroner For This Useful Post:
Old 04-13-2013, 06:53 PM   #119 (permalink)
My math
Looks to me like .81 was the frontal area "correction factor" used.
Old 06-16-2013, 07:26 PM   #120 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Hello,
VW Polo 2F (BJ 1991-1994) Coupe :
cw= 0,36
A=1,84m²
Not bad for this "coalbox"
Greetings,
Patrick
The Following User Says Thank You to Jack-Lee For This Useful Post:
cda list
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 01:17 AM
What are your 2008 mod goals / wish list? MetroMPG EcoModding Central 45 01-02-2009 01:57 AM
