Old 12-06-2016, 09:37 PM   #31 (permalink)
IIWIYS - I would put the 400 crank into the 350, and build a 383 stroker (that may be bored .030).
That engine is a torque monster.
Then run a numerically low rear end with the O/D trans of your choice, and you will always be in the sweet spot - torque-wise.
Old 12-07-2016, 07:36 AM   #32 (permalink)
It seems to me that the primary advantage of a FI engine is the tight controls on A/F ratio. What if you had a setup where you could dial in the A/F ratio on the fly as you can with carbed aircraft engines? Am I correct in assuming you can get away with some pretty lean numbers so long as you are puttering around in a low load situation and heat only becomes an issue under higher loads? If this is so, have a setup where he could drive around, very lean and if he wanted to call down to the engine room for more power, all he's have to do is give it a quick turn of a dash mounted knob? I suppose this has already been recommended by someone who said us a 4bbl with the primaries set lean and the secondaries rich. Maybe a combination of the two would be good, as I could see a situation, such as running down the hiway, where you are at a pretty decent sustained load, but not quite into the secondaries yet. In such a case, you would have the abilities to richen the primaries.
Old 12-07-2016, 01:06 PM   #33 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Drive it like you could fly it
12-Channel Digital EGT and/or CHT Pyrometer Gauge Display
This is a major investment @ 375usd +probs
The above Aviation style driving can be achieved with this gage were every cylinder has an alarm. High and low .if one gose wonky the gage can turn on a water /meth injector for that cylinder or the hole motor like a NOS FOG HAT or NOS RUNNER INJECTION ,but water/and or methanol
Sounds like this will be a custom Radio Flyer purpose bult to showcase your engine building skills , a SEMA. TRUCK. And moving non car worthy stuff.
In witch cace this artical will sted some light on how you can use the gage for tuning ,and it has a +-5%accuracy (1000°C or F on gage=950-1050°actual .
The extra probes can be used for other stuff like coolent,diff, trans,intake air . as the device will read and display all the way down past ambant (-148°)
MPG-4 Featured in Fast 20Car Magazine Issue 20332 July 20 2013 .pdf
Aerohead this is the gage for your streemliner nabor that we were talking about with the melted pistons.
They also have a 4 cylinder version for our 4banger brothers .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
RustyLugNut (12-07-2016)
Old 12-07-2016, 01:29 PM   #34 (permalink)
Buggie - '01 Vw Beetle TDI Gls
I never understood this. Ruin a 400, loose 20 cubic inches, and pay for a crap load of work, for what? The 400 would have the same torque, if not more because of the larger size.
Old 12-07-2016, 01:41 PM   #35 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
1)Reduced rotating mass 4.0"Vs4.125"bore =faster rev and higher topend 2)closer to square piston/ stroke ratio
Old 12-07-2016, 03:05 PM   #36 (permalink)
You might want to look into it further. I believe you may find things are different than you have described, on several fronts.
Old 12-08-2016, 11:01 AM   #37 (permalink)
Did a comparison last night between the 267 and the 283 w/ 601 305 heads, using the same camshaft and equal Dynamic Compression. The 267 best the 283 by 1/2 mpg but the 283 had 60 more HP at 5500. 😕 The 283 had a lot less horsepower loss than the 267 did.
Where can I find formulas for calculating (approximating) torque at a given rpm using average chamber pressure ???
Old 12-08-2016, 11:13 AM   #38 (permalink)
Would members be interested in seeing the way I modify Holley Booster for better fuel atomization and low flow performance ?
Old 12-08-2016, 11:46 AM   #39 (permalink)
silverado30mpg - '90 Chevrolet Silverado 2WD w/ 3.08 gear
90 day: 18.91 mpg (US)
BuzzBuzz - '91 Suzuki Swift GT
90 day: 159.12 mpg (US)
I'd be interested in seeing that modification. I have buddies who still run carbs.
Old 12-08-2016, 09:00 PM   #40 (permalink)
How much weight is .125 larger bore going to add? And over share will make it rev faster, but all things being equal, 20 more cubic inches add 5%more power
Seriously? Same crank. Wider bore. There is a common knowledge, the claim that having something one off is better, the misconception that everybody knows, that a 383 is a torque monster. Having the same stroke as a 400, all things are similar if you were to install (if possible) smaller cylinders. A bigger bore makes more torque because you have a larger piston area, therefore the same psi pushing down has a larger area to push down on.
Kinda why all old hoteods have/ had 350 Chevys. Everybody thinks its the coolest. So take one, make it bigger, into a 383. Still a boring SBC.
