Old 03-23-2015, 10:04 PM   #31 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
It's just a stupid upshift light, sorry if I wasn't clear on that.....
There's no eco light capabilities in our HX ecu's in North america unfortunately.
The pin that would light up the eco light instead is programmed as a shift up light.
1998 LX with a full HX swap + VX transaxle.
Old 03-23-2015, 10:16 PM   #32 (permalink)
And I bet you are correct on your white plug / up shift light theory.
My LX did not have a white plug back there at all. It had a green one instead.
Old 03-23-2015, 11:11 PM   #33 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
cool man. thanks. just curious though. what is the 4th wire? it will work without it?
Old 03-23-2015, 11:15 PM   #34 (permalink)
I'm fairly certain that 4th wire is to dim the light at night when you have your headlights on.
Old 03-23-2015, 11:19 PM   #35 (permalink)
For your upshift light I am showing the following:
Pin 1 = Red wire > dash lights
Pin 2 = Red / Blue or Red / Green > ECU upshift pin
Pin 3 = Black > ground
Pin 4 = Red / Black > dash lights
Pin 5 = Yellow > power
Old 03-23-2015, 11:56 PM   #36 (permalink)
Jakins's Avatar
you rule man. been trying to figure this **** out for a year
Old 03-24-2015, 12:18 AM   #37 (permalink)
Any ? just let me know, I have all the schematics and had to do basically what you're doing for that light.
Old 03-24-2015, 01:37 AM   #38 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
It's not for dimming as it is a constant color.
I Was googling trying to find a low voltage sensor, basically something with an independent power source to illuminate at a programmed low voltage. Anyways ended up buying a cheap $7 tiny volt meter with an independent power source to wire to my secondary o2 sensor readings. It's small enough to hide in plain sight.
I lack the engineering skills to create a sensor to illuminate at less than .9 volts
http://www.amazon.com/dp/B00C58JGE6/...Mini+voltmeter
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 03-24-2015, 02:00 AM   #39 (permalink)
I assume you don't have an ultra gauge?
Old 03-24-2015, 06:39 PM   #40 (permalink)
5 pin sensor
Nope, keeping it simple and cheap
OG lean burn member
My civic thread
