04-25-2018, 09:47 AM
#11 (permalink)
When my partner was looking for a new car recently, after looking around at sub-$4000 options, she ended up going with a 5MT Fit. Driven gently, highway economy is not that much lower than a gen2 Prius. Stop and go would favor the Prius considerably, but most hybrids in warm clients will need a battery eventually, and the Fit has far more utility than any car with better economy.
If her budget had been higher we might've gone with a Volt. As-is, we'll take the Insight on long trips and use the Fit (or my trailer) for moving furniture.
04-25-2018, 10:06 AM
#12 (permalink)
Too many cars
Depends on the driver!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
04-25-2018, 10:25 AM
#13 (permalink)
Liberty Lover
The automatics typically fail between 150k and 225k, much like on the HCH - avoid Honda CVTs unless you don't mind replacing it as your first real wear item to fail.
Thanks for those details. Are you saying to pass on 2009-2014 insights due to the CVT, or don't keep one past 150k miles?
What cars do you feel would be the best choices?
04-25-2018, 11:23 AM
#14 (permalink)
I've heard of some CVTs lasting as long as 300k with gentle use and frequent fluid changes, so it's possible, especially for a hypermiler. I just would not count on it. I have no data on whether Honda's newer CVTs are more reliable than their older ones. You'd think they would have improved though?
Sub-$5k, I'd be looking at a Gen2 Prius, or perhaps a Scion or Fit hatch. The Fit has a wonderfully tall automatic transmission which I'd trust to fairly high miles, a great engine, and you can probably stuff a pool table into it and still close the hatch. It has a rather high CdA due to its shape, but still easily breaks 40mpg with an average driver. Looking at fuel logs here, several have more than 50mpg averages with a few having some tanks above 70.
If you're feeling adventurous or can find one with a new battery, a manual transmission Insight is still the king of the hill. There are still clean ones with low miles. I would not get an automatic G1 Insight. It stands to reason that one with ~100k miles would still have many good years left in it, but you're looking at potentially 20-40mpg more from the manual and that's a hard sell for me.
In the 6-10k range, I think the Volt would be my first choice. I don't think a Gen3 Prius is a bad choice and it does better on gas alone than a Volt, but a Prius doesn't put a grin on my face like a Volt does, and those all-electric miles are certainly sweet. Both have proven to be highly reliable vehicles.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
04-25-2018, 11:32 AM
#15 (permalink)
Thalmaturge
If those are your choices, I would go with the 2010 Insight. They've been very reliable cars and do a lot better MPG-wise than their EPA numbers suggest. They do have ring issues with the 2012-2013 MY and burn a lot of oil, but the 10-11 and 14-on MY cars are normal Honda engine reliability.
I would skip any second-gen HCHs.
https://www.autotrader.com/cars-for-...archRadius=100
This one in particular seems like a better deal:
https://www.autotrader.com/cars-for-...lCode1=INSIGHT
The Following User Says Thank You to samwichse For This Useful Post:
04-25-2018, 11:57 AM
#17 (permalink)
Liberty Lover
The Insight above is G2. How is the rear visibility in your Insight?
Sacramento is not close to here. I'm south of San Luis Obispo, 93444.
04-25-2018, 12:21 PM
#18 (permalink)
I drove 700 miles to get our Fit.  Willing to travel for the right car?
This is what I see in my rearview mirror:
Subjectively, looking at the rearview mirror, it was worse than the 90's Civics I drove before I had my Insight, and worse than my partner's Fit. It's considerably better than either gen 2 or 3 Prius, which I feel have lousy visibility.
The side view mirrors have great visibility though, which I think is due to the significant rear taper of the car.
04-25-2018, 12:31 PM
#19 (permalink)
Liberty Lover
Yes I'm definitely willing to travel, but would have a hard time getting back with two cars, and not sure how to solve that dilemma.
Thanks. That looks quite bad to the sides.
04-25-2018, 12:55 PM
#20 (permalink)
Thalmaturge
Keep in mind that Gen1, then gen2 should be a bit better.
