Old 05-24-2012, 12:20 AM   This thread is in the EcoModder Project Library | #1 (permalink)
Olive Drab - '94 Honda Civic VX
90 day: 52.54 mpg (US)
Civic VX MPG project (Delete Alternator, add solar)
After a year of searching, I found a 1994 Honda Civic VX (49state) to base my project on so let the fun begin!
As the title suggests, I plan on using a solar system from SunRNR.com to allow for the removal of charging system losses. This solar system is cool because it uses a 135Watt solar panel hooked to a small battery unit. The SunRNR unit has a built in 12VDC charge controller and power invertor to supply 120VAC.
Heavy gauge power cables will connect the rear mounted SunRNR battery pack in parallel to the stock car battery and electrical system. I anticipate that removing the alternator belt and charging losses will result in sufficient gain in MPG to quickly pay for the SunRNR unit and more.
The SunRNR solar panel has a very sturdy aluminum frame which reduces the chances of damaging the panel and should allow for easy integration into a boat tail addition. It looks like the best mount will use the existing upper rear hatch hinges to make the solar panel into a new hatch. I'll upgrade the hatch support struts to hold the extra weight which will make it a functional trunk lid. Initially I'll be building the boat tail out of foam for easy shaping and aerodynamic testing. The outside will then be clad in a skin of fiberglass or aluminum and the trunk will be hollowed out leaving a layer of foam which gets fiberglass. (EDIT: The solar panel fit better on the top of the car)
The Following 3 Users Say Thank You to VXmpgRacer For This Useful Post:
LegalShieldNden (07-05-2012), turbothrush (05-24-2012), WD40 (05-24-2012)
Old 05-24-2012, 12:35 AM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Sounds ambitious, but doable. You will find others on this site who have first hand knowledge with a boat tail add on.
I have a 15w panel on my dash that keeps keeps my battery at full charge, which is useful as my cars factory alarm and various components such as ecu ect.. slowly drain off my battery noticeable without the panel in place.
I leave my car for days at a time without driving it.
Save gas
Old 05-24-2012, 01:00 AM   #3 (permalink)
Vehicle Details:
1994 Honda Civic VX Hatchback (5-wire 49state model)
Stock 1.5L VTEC-E engine with lean burn - 130k miles
Aztec Green Perl exterior with black/gray interior
The previous owner replaced the distributor and plug wires but I didn't know any other vehicle history so I went through the entire vehicle.
Initial Work Completed:
New low rolling resistance 165/70-R13 tires
New Bosch 5-wire wideband oxygen sensor
Timing belt replaced(corrected incorrect valve timing)
Ignition timing set to 16deg BTDC
Thermostat replaced
Valve adjustment
Spark plugs replaced
Fuel filter replaced
Alternator belt replaced
Oil pan gasket
Clean EGR
Clean FITV
Clean air filter
PCV checked
Remove aluminum exhaust shield
Exhaust system heat wrapped
New exhaust gaskets
Rust spots fixed
Fresh 5W-30 Mobil 1 Synthetic (will use 0W-20 next time)
FRAM extra-guard oil filter
I also added air conditioning from salvaged parts
Old 05-24-2012, 01:18 AM   #4 (permalink)
Current Modifications:
Sumitomo HTR T4 Low Rolling Resistance Tires 165-70R13
Radio antenna - Exterior antenna removed and interior antenna installed(5/13/12)
Passenger Mirror Removed(5/13/12)
Windshield wipers changed to low profile(5/13/12)
Belly Pan(6/14/12)
Vacuum Gauge(6/16/12)
MPGuino Computer(7/18/12)
Front air dam(7/20/12)
Side Skirts(7/20/12)
Solar charging and storage system(SunRNR.com)(7/25/12)
Future Modifications
Rear wheel well covers
Boat tail
Alternator belt removal (wire currently removed 7/25/12)
Wheel covers (14" pizza pans)
Old 05-24-2012, 02:02 AM   #5 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Front air dam
Belly pan
Boat tail
Rear view camera system
Quite a list. The solar system sound cool too. I'll look it up. What are you using for the internal antenna?
Old 05-24-2012, 11:23 AM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to the forum! Subscribed to this project.
Have you done the math on the solar payback time? How much does the panel/battery combo cost?
Old 05-24-2012, 08:32 PM   #7 (permalink)
The radio antenna is a cheap ebay unit that is adequate but I wouldn't necessarily recommend.
The payback period of the solar system depends totally on the mpg change and current fuel prices but I put it at less than 150,000 miles if I gain a few mpg. Depending on how the unit works, I may also try using an electric motor to turn the air conditioning pump to eliminate those losses.
Old 05-30-2012, 11:36 PM   #8 (permalink)
5/30/12 Project Progress:
Increased the ignition advance to 18deg BTDC
Mounting the SunRNR power unit
Using a large hammer, I made room for the SunRNR to sit inside the spare tire well. It is my hope that placing the unit lower to decrease the effect of it's weight on performance as well reduce the space loss.
(EDIT: I ended up taking the unit apart and mounted the battery behind the drivers seat)
Old 05-31-2012, 12:10 AM   #9 (permalink)
More about the SunRNR:
Charger controller
12VDC - 30amp capacity
Multiple input formats (solar, windmill, 12VDC)
Inverter
Input 12VDC
Output 25.5 Amp @ 120VAC = 3060W
Huge Deep Cycle Battery Manufacturer Specs
1100 Cold Cranking Amps
210 Amp Hours
Valve Regulated
Absorbed Glass Mat (AGM) Technology
Lead Acid
Solar Panel 135W
Old 05-31-2012, 10:20 AM   #10 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I like the idea of solar assist, however the cost seems extreme.
Can you please give a link to the specific unit your using.
Also just a personal choice .. I run Mobil 1 Synthetic 0/20 in the winter and 5/20 in the summer, I would wager that unless your VX is spewing oil, all your doing is killing your potential MPG with the heavy oil.
I would never run a Fram filter .. Wix is the way to go.
2000 Insight MT 106K Citrus A/C
The Following User Says Thank You to WD40 For This Useful Post:
VXmpgRacer (06-01-2012)
alternator delete, high mpg car, honda civic vx 5-wire, solar car
