Old 07-25-2012, 08:04 PM   #21 (permalink)
Olive Drab - '94 Honda Civic VX
90 day: 52.54 mpg (US)
The car wasn't lowered at all but looks very low. The coroplastic front lip will bend out of the way when it hits stuff so I made it pretty low.
The Following User Says Thank You to VXmpgRacer For This Useful Post:
sully06 (05-06-2014)
Old 07-25-2012, 08:09 PM   #22 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
very nice
2000 Insight MT 106K Citrus A/C
Old 07-25-2012, 08:11 PM   #23 (permalink)
Deep Cycle Battery Installed
I finally got the large deep cycle battery installed. The charge controller is now right behind the Emergency Brake so I can see it from the drivers seat. Under the charge controller is a fuse block to help prevent a fire.
Old 07-25-2012, 08:20 PM   #24 (permalink)
Old 07-25-2012, 10:42 PM   #25 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by VXmpgRacer View Post
The car is looking good! This will likely work to reduce your overall drag, from what I have read here. I had an airdam that low and it got banged-up noticeably quite quickly. If you have speed bumps or deep dips like I do, it'll happen to you too, likely. I now have a new dam and side skirts and I stay a little further off the pavement.
How many amp hours will that one give you, and how are you charging it? Just the panel? You have it well secured and vented?
Old 07-26-2012, 01:51 AM   #26 (permalink)
The battery is rated at 210Ahr.
This project is just starting the testing phase. I disconnected the alternator wire and it is only using solar to charge. Hooking a charger to it at night is an option.
The battery and box are well secured with two ratchet straps.
The Valve Regulated Absorbed Glass Mat battery is meant for confined area's with poor venting and is currently vented directly to the cabin.
Old 07-26-2012, 09:49 AM   #27 (permalink)
Cyborg ECU
Thumbs up
Wow!
I hope I can be some help for the plan/testing, having had a deep cycle battery and alt delete running for almost a year. So my questions are in that spirit: Won't a 210 ahr battery need at least a 90amp charger or an equally powerful alternator to get a true full charge? With less, won't the battery degrade in its ahr capacity kinda quickly?
Old 07-29-2012, 07:15 PM   #28 (permalink)
SunRNR has done a lot of research on this combo of solar panel, charge controller, and battery. I trust that their system will hold up well.
Old 07-30-2012, 10:50 AM   #29 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I have not heard/ read about ah losses due to low amp charging.
I am still under the belief that slow/ low amp charging is superior to fast / large amp charging. In short the fast charge is reported to dissipate faster.
Could you enlighten me with some information or a link ?
I seem to have a gap in my knowledge bank.
Save gas
Old 07-30-2012, 11:17 AM   #30 (permalink)
Charging batteries fast wares them out like discharging them fast.
Charge them as slowly as you can get away with.
alternator delete, high mpg car, honda civic vx 5-wire, solar car
