11-25-2013, 02:57 PM
Civic VX O2 Sensor Conumdrum
Okay folks, I'm presently looking for the definitive answer to which type of O2 sensor that I would need to buy to enable lean burn on my 94 Civic Vx. I just recently purchased the vehicle, whereas the NTK O2 sensor that's currently installed is stamped as LZA09-E1. I'm not certain; but I think that this may be the wrong one.
To get right to the point, am I stuck with purchasing the OEM version, or is there a comparable aftermarket sensor that will give me the same result as the factory OEM O2 sensor? If so, who makes it, what's the part number, and where can I find it? Also, it would be great to hear from any member of this forum who can attest to utilizing one.
My car is a stock 94 Civic VX Federal, with the D15Z1 engine and 5-wire O2 sensor. Overall, the car runs fine; but my gas mileage has been lousy.
Thank You.
11-25-2013, 06:09 PM
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
That's the same one I run. Its correct, but may be dying. Here's the listing details:
NGK Partfinder for Cars & Light Commercial Vehicles
I'd suggest looking elsewhere for issues.
Shooting for 600 miles of range at 65-70 mph out of a vx.
11-25-2013, 09:13 PM
Originally Posted by xntrx
You may very well be right. I've already considered buying OEM plugs, wires, cap & rotor, pcv valve etc. I'm just attempting to do a little forward thinking in the event that a major tune-up doesn't resolve the issue of poor fuel economy. After all, I think that everyone can agree upon starting with the cheapest things first.
I'm presently running in the low 30's, whereas fuel economy has seemed to have dipped in the last two weeks. Tire pressure is even up to 40lbs.
Finally, when I pulled the O2 sensor, it looked very black; but so far, I'm not getting a check engine light.
11-25-2013, 11:41 PM
It's rare for the o2 sensor to throw a check engine light code, unplugging the o2 sensor is the most common way to test it as most people feel a stumbling with a failed o2 sensor.
Bad exhaust or over sized exhaust is the most common caused of a dead o2 sensor.
11-26-2013, 08:54 AM
I bought one off Rockauto.com and its been working great. I dont remember the brand but after next day rush shipping it was $160ish. Ive never had any issues with it and enter and exit lean burn very smoothly
11-26-2013, 09:41 AM
I'm no master mechanic, but I certainly enjoy trying to tune up my cars for more mpg. I would pull the spark plugs and check the health of things there. Then, I'd look other places.
What kinda mileage on this beast?
11-26-2013, 03:26 PM
Hmm, incidentally the car does need a new exhaust. So are you saying that to test the O2 sensor, I must unplug it and see if the car stumbles?
11-27-2013, 12:52 PM
Maybe read up on a plugged catalytic converter too. Just an idea.
11-27-2013, 04:03 PM
#9 (permalink)
I probably should mention that before I bought the car, I'd gotten an independent inspection from a mechanic. Thankfully, there was no mention of a plugged catalytic converter.
But to put things back on track, I'd like to know what aftermarket O2 sensors would work for when the time comes when I actually need one. I understand that the Bosch 13246 sensor is actually stamped as L1H1. Can anyone confirm this fact?
11-28-2013, 10:00 PM
#10 (permalink)
A bad o2 sensor will make the car stumble, unplug the o2 sensor and it will stop stumbling.
