Old 05-23-2022, 04:47 PM   #41 (permalink)
EcoModding DIY aer.or
I made it to 15...
https://www.mk1autohaus.com/assets/images/251819015.png
The Following User Says Thank You to sregord For This Useful Post:
aerohead (05-23-2022)
Old 05-23-2022, 05:08 PM   #42 (permalink)
blowers
Looks good! The unit has a double squirrel-gage. ( twice the fun! )
What I experienced on the BOSCH, was that, as the envelope filled, and the fan was just dead-headed, no longer actually moving a volume of air, and just providing static pressure, the fan power draw fell off, kinda just 'cruising.'
And regardless of the constant electric load on the alternator, the T-100 went over 30-mpg for the 1st time.
Whatever you do, DO NOT use expandable Naugahyde automotive upholstery fabric. The envelope will not maintain its dimensions, wrecking the aerodynamics.
The advertising folks use a Hypalon-impregnated aerospace fabric. Rip-stop Nylon will work, but it needs UV protection. ( it can kill a perfectly good parachute ).
Old 05-23-2022, 05:19 PM   #43 (permalink)
Billboard covers?
I have alot of that.
Old 05-23-2022, 05:33 PM   #44 (permalink)
Billboard................
Originally Posted by sregord View Post
Billboard covers?
Nice! You'd think it's engineered for exposure to the elements.
Marine-grade thread is also designed for the outdoors. You sure don't need seams ripping out on you.
Old 05-26-2022, 03:03 PM   #45 (permalink)
Maybe I should start with a belly pan?
I have this ...tickle in the back of my neck about the future of this MH(Moby)... and its sell ability.
An improvement that doesn't effect the look.
Curious: I see many using coroplastic to smooth the underside... good because of weight, 9#s- 5/32"-4x8 sheet, but needs a fair bit of "structure" to rivet or screw to.
Has anyone used 21#s- .181" -4x8 plywood, sealed/painted with epoxy (Patio/concrete paint). It has alot of shear, and "twist" resistance. Neither belong near hot exhaust obviously, but 3 sheets under a Honda would equal a 36# difference, but would require less brackets, & frames. Moby would need ~7 sheets
Old 05-26-2022, 03:15 PM   #46 (permalink)
belly pan
If you can locate orbywan's old RV posts, you might find time-saving tricks he used. He got his Ford MH up to 14.5-mpg.
Bigrigdave (04-23-2023)
Old 05-26-2022, 03:19 PM   #47 (permalink)
Aero RV
If it's been mentioned in this thread, I missed it.
A good example of a boat tail on a motorhome was done by user Orbywan a few years back. Did you review his build and results?
https://ecomodder.com/forum/showthre...d-e-18151.html
Imagine that. Both posted about it at the same time.....
The Following 2 Users Say Thank You to ennored For This Useful Post:
aerohead (05-26-2022), Bigrigdave (04-23-2023)
Old 05-26-2022, 03:21 PM   #48 (permalink)
Aero RV ( custom boat tail for '95 Ford E-350 Class C Motorho
See if this is enough to locate Orbywan's RV mods.
Old 05-26-2022, 03:24 PM   #49 (permalink)
Funny!
Yeah, 14.5-mpg got everyone's attention!
The rooftop fairing for the Colemen AC units are now used by Boeing Aircraft Corp. on their 737 MAX 800.
Old 05-26-2022, 03:28 PM   #50 (permalink)
WOW... 14.5MPG?
I did find the older thread :
https://ecomodder.com/forum/showthre...n-s-18427.html
More research
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
