Old 05-12-2014, 02:20 AM   #21 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Wait guys, can't coasting in neutral at high speeds with an automatic fry the transmission?
Old 05-12-2014, 10:47 AM   #22 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
In most cases it's fine. I can personally vouch that it's fine in a Honda. If the engine is running, there's a pump that's lubricating the transmission.
Some automatics don't tolerate engine-off coasting. Hyundai is one. Some are ok with it. Some have "limits' like Honda: up to 35 mph for up to 50 miles. Since I never coast for 50 miles at a time, I feel it's ok to push the mph limit a bit. Then again, the gains from EOC at highway speed are much smaller than in the city, so it's less relevant there.
Old 05-12-2014, 10:48 AM   #23 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
I believe that only applies to engine off neutral coasting.
Old 05-12-2014, 05:47 PM   #24 (permalink)
It was actually a factory feature in the automatic versions of the Opel Astra, which had been briefly offered in the U.S. and Canada as Saturn Astra. AFAIK this very same transmission was used in nearly every late-90s compact sedan such as your Corolla
Old 05-12-2014, 06:05 PM   #25 (permalink)
I've coasted in neutral (only engine running) in autos for probably a decade, several different cars, regular autos, CVTs, and 23+k in the fiesta powershift.
Engine off coasting in neutral?
You will never see me do that in any auto transmission. In almost ever auto tranny made there are two flanges on the back of the torque converter that engage the primary pump of the transmission. When you turn the engine off, the torque converter stops rotating, since it is bolted to the crankshaft, so you have no primary pump and no pressure for gear actuation or lubrication, and neutral needs activation to unclamp all of the bands that engage the planetary gearsets.
Would you run your engine without oil pressure intentionally?
You will never see me coasting in neutral, with the engine off, in any auto transmission, until the manufacturer guarantees me that they will replace the transmission if it fails.
They won't.
Engine on only in autos. Engine off is risking a several thousand dollar repair, in many cases more than the car is worth.
Manuals are fine with engine off coasting.
regards
Mech
Old 05-12-2014, 10:46 PM   #26 (permalink)
Furry Furfag
They won't.
regards
Mech
Thanks Mech, this is the answer I was looking for. I never engine-off coasted in my Camry, and I'm glad now I didn't ;D
Old 05-13-2014, 07:24 AM   #27 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
They won't.
regards
Mech
Have to agree. Was in the towing business back in antiquity. Lots of rules about about which automatics could be towed drive wheels on the ground. Some X number of mile at <Y speed others not at all. These assumed the transmission was in good condition. Best bet was flatbed, drop the drive shaft or dolly.
Old 05-13-2014, 12:07 PM   #28 (permalink)
I wouldn't do so, but an uncle of mine once towed a Pontiac Trans Sport with the drive wheeld on the floor, using a towbar.
I'd rather use something like this if I couldn't get a dolly
Old 05-13-2014, 12:09 PM   #29 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
Old 05-15-2014, 06:41 AM   #30 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Is it just me or are space saver spare tyres getting smaller and smaller?
