Old 03-15-2010, 04:17 PM   #291 (permalink)
MechPal Tech Founder/CEO
DeathTrap - '93 Geo Prizm
90 day: 30.03 mpg (US)
Beatrice GEN1 Platfrom - '95 Chevrolet Silverado C/K1500 C/K Silverado
90 day: 51.32 mpg (US)
Suggestion
Mr. Bondo (Brett),
First off, allow me to say that I have been searching for ways to save cash, and found your most perplexing and dynamic design.
I know this is a LONNGGG time from when the posts first started, however, I urge you to submit this to the Pepsi Refresh Project. This may be both a great promotional tool, and definitely a way to win dev and production money.
Lt. David H. Young
The Following User Says Thank You to MechPal For This Useful Post:
bondo (03-15-2010)
Old 04-01-2010, 09:37 PM   #292 (permalink)
Odd - '04 Ford Ranger
90 day: 33.29 mpg (US)
Angle
Hello, I'm thinking about doing a similar aerobed on my truck and am wondering what angle you've got on the taper. I've heard 10-12 degrees is the magic spot, what have you seen work/not work.
Old 04-01-2010, 10:08 PM   #293 (permalink)
90 day: 57.73 mpg (US)
Hi cons - the ideal angle varies depending on the truck (cab height, bed length).
10-12 is likely a safe bet if you're talking about a conventional pickup.
The key is a smooth transition to the ultimate angle, rather than an abrupt transition from horizontal (cab roof) to 10 or 12 degrees.
Old 04-02-2010, 01:31 PM   #294 (permalink)
Thanks, that'll be very helpful. Also, I'm wondering if it will be better to tuck the side panels in 10 degrees, and let all of this extend past the tailgate a foot or so for better airflow detachment at the end. Do you think that'll make much of a difference?
Old 04-02-2010, 03:26 PM   #295 (permalink)
bondo's Avatar
Welcome to ecomodder cons and best of luck with your project. Several people on this site have constructed some really nice aerocaps using a variety of materials.
MetroMpg is right on about the key being a smooth transition off of the roof of the cab into the ideal angle of the roof of the cap. Since to sides of an aerocap become smaller as it moves rearward, I don't know if angleing the sides will have much benefit.
Here is some video of the Aerolid showing the flow of attached air along it's surfaces. This is just one example to follow in determining the shape of your aerocap. Even though the sides are not angled in, the air remains attached, along the sides, almost to the rear corners.
Bondo
The Following 3 Users Say Thank You to bondo For This Useful Post:
aerohead (04-03-2010), tbonrsteak (06-15-2010)
Old 04-09-2010, 04:24 AM   #296 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
CR-EX - '12 Honda CR-Z EX
Send a message via Yahoo to bluetwo
That was cool seeing your lid in action. Nice job!
Old 04-11-2010, 08:54 AM   #297 (permalink)
MPG Maniac
100MPGUS's Avatar
Originally Posted by bondo View Post
Metrompg,
My name is Brett and...
I tried to gain funding through the government. Nothing! I emailed my Senator on the matter four times and got no response. I emailed him a fifth time asking where I might send a campaign contribution to? I got a response to that email in less that 24 hours!...
I am honored to be in the company of those who pursue fuel efficiency,
Brett Herndon
Little Rock, Arkansas
Well, not surprised, just disgusted. I am sure there is someone out there with the money do get your product to the market. You just have to keep looking.
Old 06-01-2010, 07:40 PM   #298 (permalink)
Hello, I added my top 2 months ago and saw a 5 mpg improvement on average. I angled it at 12 degrees and extended it past the tailgate 8 inches for better air cut-off. Apparently I can't post pictures of it though because I too new to this website to qualify for that. I average 33mpg on the 2004 Ford Ranger 2.2L 2WD. These have always been in less than ideal conditions (all mountain driving with loads), so I think if I go 55 mph on flat ground I could get a higher score.
Old 06-01-2010, 07:43 PM   #299 (permalink)
Working on my number of posts here so I can add pictures.
I made the top out of Polycarbonate (Lexan) over an aluminum framing.
I gorilla taped all the edges so it's a smooth transition, as opposed to the other aerobeds that have a gap between the canopy and the cab.
When I screwed the rear down, my mpg dropped, so I undid that.
Old 06-01-2010, 07:47 PM   #300 (permalink)
Also, I had leftover lexan that I immediately taped onto the wheel wells. I never independently tested it (I just couldn't resist putting it on!) I know I'll catch flak from the hyper-accurate posters here.
Anyhoo, the top is really solid, $250 for materials. Went up in 2 days, and is working very well. I can see through it when I'm driving so it's great for that. Also lightweight. One of the problems is on dusty roads, it gets inside easily. And I can't lock anything in the bed, which is plainly visible too.
Getting a lot of rubber-neckers checking it out.
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 06:46 PM
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 03:35 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
How much do y'all pay for trash pickup? roflwaffle Saving@Home 15 08-23-2009 11:46 AM
Daihatsu Mira aerodynamic modifications newtonsfirstlaw Aerodynamics 5 06-13-2009 10:43 PM
