Old 09-17-2020, 02:10 PM   #31 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
After installing the Scott's solid metal undertray on my Insight (instead of the two smaller pieces that cover 1/3 of the area under the engine each), I found the car took longer to warm up and had a harder time maintaining coolant temperature under lean burn conditions on the highway.
I ended up having to partially block the lower grill area to compensate.
The Following User Says Thank You to samwichse For This Useful Post:
Nautilus (09-18-2020)
Old 09-17-2020, 04:26 PM   #32 (permalink)
If you were to go bigger with the front undertray (including filling some of the front wheel air exit openings), you'd then find that radiator cooling flow starts to decrease. That's what happened on my Insight.
So a good example of cooling airflow being controlled by altering the exit openings.
Old 10-11-2020, 05:55 PM   #33 (permalink)
Simba - '05 Seat Leon FR
Originally Posted by Nautilus View Post
If deflectors before front wheels really give a delta Cd of 0.01, this drops the overall Cd from 0.32 in the 0.28 range, which is actually very good for a daily-driven car.
Originally Posted by JulianEdgar View Post
You cannot just ascribe Cd reductions to a car based on what the change did on another car. (Same as you cannot just add Cd reductions together to get an assumed total reduction.)
I've also used the downloadable Excel Drag Coefficient calculator.
Frontal area for a Mk I Seat Leon has been published as 2.011, 2.20 or 2.28 sq m. Used an average, 2.16 sq m.
Weight of the car, with all bits and bobs as of Oct 2020, falls around 1364kg. Added driver weight and fuel weight (gasoline density average 0.748 kg/liter) for a total weight of 1471kg.
Tire rolling resistance for passenger car tires may be from 0.007 to 0.015. Tires were rated "E" in fuel economy, so I've assumed the worst and used 0.015.
After filling in the speeds with car coasting down in neutral, Excel formula gave a Cd figure of 0.29 (actually 0.290031, but sixth decimal place figures are too small to matter in Real Life).
As we can see, I had been too optimistic pulling a 0.28 figure from the hat, but my labors over the last few years had not been in vain.
Old 10-11-2020, 06:00 PM   #34 (permalink)
I think that coast-down tests are completely inaccurate - it's one of the two things that Aerohead and I agree on.
Putting invalid data into an Excel spreadsheet suddenly doesn't make the data correct.
At minimum do some testing windows up / windows down and see if the difference makes sense in terms of calculated drag. It doesn't when I do this with multiple runs and averaged results.
Old 04-16-2023, 05:21 PM   #35 (permalink)
Just came back.
Had some very unpleasant adventures with the car as the last wave of the pandemic unfolded. The car is now on its second coolant radiator, second set of power steering lines, second set of coolant plumbing, third oil cooler and fifth timing belt and kit of its life and let's cut the details.
Undertrays and other under car bits and bobs have been slightly improved. Now the front undertray is about 3 in longer, almost below the front end of the catalytic converter. It's safer to leave most of the catalytic converter surface exposed to air. There are also two trapezoidal "wing" undertrays on the two frame rails of the car, on the sides of the catalytic converter, so to keep most of the air stream as close to the centerline of the car as possible. The proof they work is the fact just after fitment the wind noise at high rpm and speed decreased even further. Also the fitment of aluminum undertrays around the rear suspension and the bends of the exhaust is tighter. The weight at the rear has also been slightly increased.
This is a rough sketch of the general shape of the undertrays. In the light blue areas the bellypan of the car had already been mostly flat.
A mixed run, about 25% city streets with very little traffic and 75% highway with some traffic, has yielded visibly better fuel economy. Previously same traffic conditions and driving style (highway speeds with some use of the turbo) might have given 30 to 32 mpg on the dashboard indicator. This weekend it has shown about 37 mpg and then about 34-35 mpg on the return run.
Never in the last 18 years have I seen such figures in a normal run. 36-37 mpg could be done in the past only if I did all efforts to hypermile, and this negated all reasons to buy a turbocharged engine at all.
As we can see, compared to 30-32 mpg before 2020 and factory given highway fuel economy of 27 mpg, the labor, materials and Cd improvement (whatever it is) just paid for themselves.
LATER EDIT:
Repeated the test on a different road to make sure previous 2 figures weren't lucky shots. 25% light city traffic, 75% moderate highway traffic, moderately high speed with some 120-140 km/h (75-87 mph) runs at maximum rpm where the highway was free. Indicated average fuel economy in the dash was ~34 mpg.
Absolute record for the last 18 years of the car's lifetime: dash indicated 6.1 l/100 km (38.56 mpg) for a 58 km (38 miles) drive, out of which 9 km (5.6 miles) evening city traffic and the rest busy (many 18 wheeler trucks) highway traffic.
The Following 2 Users Say Thank You to Nautilus For This Useful Post:
freebeard (04-16-2023), me and my metro (04-16-2023)
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
Ethanol problems ? Denis DIY / How-to 16 05-31-2011 05:14 PM
2 problems with Scangauge II. Can you help? regor EcoModding Central 11 10-29-2008 11:23 PM
Winter weather mod problems.... justpassntime Aerodynamics 7 08-05-2008 11:35 PM
problems with EVs igo Fossil Fuel Free 26 01-16-2008 12:15 PM
