Old 11-13-2019, 02:58 PM   #1 (permalink)
Coroplast - supporting bracing for "Aero Tail" on my trailer
(Read a LOT of posts about coroplast, especially the RV with the boat tail...)
How much BRACING is required to support these 4'x8'x.156" coroplast tails behind my 6'tall x 8'wide enclosed snowmobile trailer?
Should I run just a 1"x1" aluminum angle, in the two upper corners? (Indicated in RED in photo).
And 2 more angle-aluminum in the lower corner (edge) also?
Do I need more structure, as in creating a "picture frame" of the 4 corners, and tying them all together... (pictured in BLUE)?
ID:	27170   Click image for larger version
ID:	27171   Click image for larger version
ID:	27172   Click image for larger version
Old 11-13-2019, 07:08 PM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
There's probably going to be a lot of buffeting, and coroplast isn't as heavy duty as the ones the big rigs use. I'd go with the picture frame.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
Xist (11-20-2019)
Old 11-14-2019, 09:01 AM   #3 (permalink)
Edge support is nice, but I believe you would be better off anchor supporting the centers since it would reduce flex and stress
Old 11-15-2019, 05:37 PM   #4 (permalink)
Do you have the Coroplast yet?
What are those stringy white things in the fourth picture?
Old 11-18-2019, 10:08 AM   #5 (permalink)
Have NOT purchased anything (yet).
The frame design was from the RV thread... I was thinking of just doing the 4 corners, and picture-fame (tying 4 sides together at center).
https://ecomodder.com/forum/showthre...d-e-18151.html
Old 11-18-2019, 11:20 AM   #6 (permalink)
Cool. Coroplast is not fit for purpose. It's fine for mockups and experimentation, but the final material should be Polymetal or equivalent (Alumapanel, Grimco Maxmetal).
It cost more than plywood but is 1/10th the weight. The samples shown were sheared, rolled and braked by hand.
It is pre-finished and would match the build quality of your trailer.
Polymetal has sufficient shear strength, you could make it a monocoque box. With Cardboard Aided Design or Coroplast, you'd want a frame that is triangulated.
http://hiataircraft.com.ua/wp-conten...14/06/fuse.jpg
The Following 4 Users Say Thank You to freebeard For This Useful Post:
Chonk_Master (04-10-2020), Fat Charlie (11-19-2019), slowmover (11-19-2019), Xist (11-20-2019)
Old 11-19-2019, 01:11 PM   #7 (permalink)
90 day: 19.36 mpg (US)
The forces on the tail are FAR greater than coroplast can handle.
There are about three designs of trailer tails on big trucks. Take some pics at a truckstop. Open and closed.
See the STEMCO site. That fully boxed version is great for FE. But in a heavy crosswind it’s leveraging the trailer wheels off the ground. The driver doesn’t have his trailer tandems as far back as allowed, he’s in trouble.
The Following User Says Thank You to slowmover For This Useful Post:
Xist (11-20-2019)
Old 01-16-2020, 07:22 PM   #8 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
4x8sheet $69.30usd and a little more durable final skin
8mm Twin-Wall Polycarbonate Sheet - 47.25"W x 96"L
Support required depends on pressure balance and forces involved
The one being a picture called a picture frame I see as a bird cage support structure you would either bend the colorplast over the framing or cut panels to fit between the frame sections like gussets.
Pressure balance as mentioned is critical to dealing with off angle wind or side wind. Couple of days ago driving South through Idaho in a ground blizzard even pressure balance was very important the front tires would actually slip a little as they hit the ice first giving me time to respond with the drive tires
Old 01-16-2020, 07:43 PM   #9 (permalink)
Better than Coroplast but it's still brittle. I have canopy/bridge between my Airstream and carport made of the stuff.
It's less flexible than Coroplast.
Old 01-16-2020, 09:34 PM   #10 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
10mm it's what I used to create the internal structure of my nose cone using a heat gun I was able to bend it into oval shape. Extremely Ridgid Id say 60lbs centered on a 3 'span perpendicular to the web=1/2" deflection , using an 8' pice for a temporary shelf
As for spacing of support it depends on if the support is with the perpendicular web or acrossed it.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
freebeard (01-16-2020)
