08-29-2013, 08:17 PM
#41 (permalink)
Originally Posted by Frank Lee
Effort?
I thought the concern was wearing out the power window.
In the end, every consideration is one of effort. It can cost money to replace dashboards that are destroyed by sun and heat, or it can cost money to replace worn out window actuators. Money = work = effort. Also, putting up sun shades or cracking the window is effort.
Abstractly, having to run the AC for a longer duration due to heat will cost more money, which takes effort to make. But then again, buying a sun shade takes effort as well.
Heck, even global warming is an argument about effort. Does it take more effort now to reduce the negative consequences of global warming, or would it take more effort later to mitigate those consequences (rhetorical question)?
08-29-2013, 09:11 PM
#42 (permalink)
Coasting in the Carolinas
If its over 70F outside I crack my windows 1" or more, unless rain is falling. Common sense.
Proper Prior Planning Prevents Piss Poor Performance.
08-30-2013, 10:20 AM
#43 (permalink)
Hypermiler
Originally Posted by wdb
Someone gave me one of those for a gift. Useless. A hassle to install, and if you plan on driving over 40 mph you really need to remove it due to wind noise. It's noisier than having the window cracked open the same amount. After a few times installing and removing it for minimal cooling effect, I gave up and left it off.
08-30-2013, 10:23 AM
#44 (permalink)
Hypermiler
I live in Texas. It's going up over 100 today, like it did yesterday. My windows are cracked an inch. My sunshade is up, car parked to face the afternoon sun.
When I approach the car, I walk around and open all the doors and the hatch. Get in, key on, roll down windows, key off. Get out again, walk around and close the doors. THEN I get back in and buckle up, take down the heat shield, put on glasses, etc.
08-30-2013, 10:42 AM
#45 (permalink)
^That. Even when I'm a passenger getting into a hot car I leave the door wide open until the driver is all situated and ready to start up.
08-30-2013, 10:43 AM
#46 (permalink)
It took more effort to type that out than it does to crack a window open a bit.
08-30-2013, 12:27 PM
#47 (permalink)
Ok, I misunderstood the ECU location. Most of the work I've done has been on larger vehicles (trucks, etc.) and by ECU I thought you meant the Engine Control Unit (aka ECM) not the Electronic Control Unit (what I'm used to referring to as a "body computer").
I understand now.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
08-30-2013, 12:33 PM
#48 (permalink)
Ultimate Fail
I do the pretty much the same.
Curious - you say you 1) get in 2) key on 3) roll down windows , key off.
Key on ?
08-30-2013, 12:54 PM
#49 (permalink)
Hypermiler
Power windows. Turn on / Boot up the car, but certainly don't start the engine until I'm ready to roll.
08-30-2013, 12:55 PM
#50 (permalink)
Power windows.
