05-16-2014, 10:10 PM
#31 (permalink)
I'm going to draw a bright red line from here:
To here:
I just measured my flat-screen Beetle. The windshield is 42" across at the base. The top have a curved edge most cars don't offer.
If you want to go head over heels down the geodesic rabbit-hole, you could do worse than Domerama.
Here's a pattern that shows how to turn a sheet into a compound curve with three relatively small incisions.
Cover Templates for 3v 5/9 Geodesic Dome » Domerama
05-17-2014, 07:10 AM
#32 (permalink)
I agree with finding a current windshield that closely matches how you want the end result, and work around that. It'd be the least expensive way, and DOT approved. I think a windshield starts around 60 bucks at the junkyard here. Then you can cut it to the size you need. (This can be a real pain in the rear if you do it yourself. You have to have lots and lots and lots of patience.)
05-17-2014, 03:20 PM
#33 (permalink)
Too much work. Look at the Kickout SS again. The lower edge is sunk into the cowl to hide the windshield wipers. It all comes down to how short a wiper you can make.
05-17-2014, 03:56 PM
#34 (permalink)
What about the sides?
05-17-2014, 04:01 PM
#35 (permalink)
It is a lot of work, I had to cut 7 inches off both side the windshield I am using to get the width i wanted. Sinking the glass into the cowl though lets you play with the height a lot easier though without the cutting.
05-17-2014, 05:21 PM
#36 (permalink)
Seatofpants -- What's the finished width?
Xist -- Thanks for asking. I get to point to the Volkhart-Saggita.
Notice the compound[?] curve to the door windows.
Also the Subaru SVX
05-17-2014, 06:26 PM
#37 (permalink)
Windshield glass is about 33" across.
05-25-2014, 07:28 PM
#38 (permalink)
I have a Blackjack Zero (BJZ) that came with a small polycarbonate snap on windshield. It sounds cheesy, but actually worked and looked very good. I wanted a roof for the car so I needed a permanent front windshield to mount it to. The BJZ is very small. I spent 2 years to decide to best course of action since I only needed one. Issues like price, availability, fit, weight, etc. were very important to me. I decided to cut an existing manufactured windshield down to my needed size. I was able to do it in my garage for a total cost of $1,323 and weight of 17 pounds. This includes the tooling I needed to buy. My case is somewhat different than yours, but many of the same issues are there. I am not able to submit links due to I have less than 5 posts in this forum. You will need to do it the old fashioned way and go to Facebook and search Blackjack Zero. My site will pop up. You will find a windshield photo album with about 100 pictures in it. You will also find the procedure for this project in the "Notes" section. There is a lot more stuff on the site if you want to learn about other things.
05-25-2014, 08:25 PM
#39 (permalink)
Kids these days...
So, about the Blackjack Zero. How long have you had it? Buy or build? Have you had much contact with the manufacturer?
05-26-2014, 02:50 AM
#40 (permalink)
Why don't you do everyone a favor and make two posts in here: http://ecomodder.com/forum/showthrea...ase-29018.html
I dare you to be off-topic!
