Old 11-06-2012, 12:49 AM   #61 (permalink)
Originally Posted by Christ View Post
In general, the SSSA is just as strong as, if not stronger than traditional "grapple" style swingers. They're usually over-engineered to deal with non-standard and non-linear stresses.
Almost every currently-made BMW motorcycle has single-side swing-arm and no one says they're not strong enought
Old 11-17-2012, 01:18 PM   #62 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Any updates?
Do you plan on upgrading the magna suspension and using a car tire in the rear?
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 11-17-2012, 03:33 PM   #63 (permalink)
Originally Posted by HydroJim View Post
Any updates?
No seem strong if any thing air shocks but the stock ones seems right will see
As for updates building exhaust system. Picked up a 10' 1.5 pipe today 25 buck and a short glass pack muffler with a 1.75 inlet and a 1.5 outlet. will add pics when I get all parts gathered up
Old 11-26-2012, 02:41 PM   #64 (permalink)
Ok here is pics of the eco exhaust system all clamps so I can change if needed. I also got rid of the kid springs and got it back to a stock height for now thing was 2" off ground from the radiator support
ID:	11936   Click image for larger version
Old 12-01-2012, 10:46 AM   #65 (permalink)
updates: gas tank started .Will hold about 10 gal using the stock crx pump and sending unit. Will hook up to the stock gas door.
Header and muffler installed.
and if your wondering the rim is a 38 chevy coupe
ID:	11967   Click image for larger version
Old 12-01-2012, 11:04 AM   #66 (permalink)
HydroJim's Avatar
Are you making the tank out of steel?
I was thinking of buying a racing fuel cell for my trike build
Old 12-01-2012, 03:33 PM   #67 (permalink)
yep 16 gauge
I got a 8 gal one for it but can not hook to crx fuel door right.
Old 12-05-2012, 12:04 PM   #68 (permalink)
10 gal tank with fuel pump and sending unit. Will be adding a tank sealer
Getting close to the modified rear end time..Had to lower pump filter to bottom of tank and extend fuel sending unit to read fuel right.
Old 12-06-2012, 12:53 PM   #69 (permalink)
ok some pics of tank
ID:	12008   Click image for larger version
Old 12-06-2012, 09:22 PM   #70 (permalink)
HydroJim's Avatar
that's looking good. Is there any negatives to using steel as a fuel tank? I'd be worried about sparks and oxidation, but I have no basis for my argument. Just what is inherently coming to me.
Then again, I think there are plenty of steel fuel tanks in the world, so nevermind
