Old 06-10-2008, 04:59 AM   #1 (permalink)
88CRX - '88 Honda CRX Standard DX
90 day: 32.74 mpg (US)
IS250 - '07 Lexus IS250
90 day: 25.79 mpg (US)
RX300 - '00 Lexus RX300
90 day: 18.38 mpg (US)
CRX Mugen Wing?
I think this is a mugen style wing:
Do you guys think it will decrease Cd?
Old 06-10-2008, 07:42 AM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I might help. Worst case it'll change nothing.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 06-10-2008, 08:15 AM   #3 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
I think it'll make it worse due to the wraparound sections on the sides.
Old 06-10-2008, 08:36 AM   #4 (permalink)
90 day: 51.82 mpg (US)
It won't do much with that sunroof open!
The side portion shouldn't hurt, provided it follows the existing body taper (or is slightly more tapered). Hard to tell from the pic, but it looks like it at least follows the existing lines.
Old 06-10-2008, 11:55 AM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
The mugen wing does follow the existing lines...I've always wanted one.
Old 06-10-2008, 12:04 PM   #6 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
it will extend the tail out a bit making a very slight angle decrease to the hatch .. doubt you'll see a big difference but looks basically like a kammback mod.. on a tamer scale.. couldn't hurt
Old 06-10-2008, 02:26 PM   #7 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
IF the wraparound sections follow the body lines, I would say it could only help by a negligible margin.
IF the horizontal piece follows the body line, its kammback properties might be negated by the increased wetted flow area. Remember, the purpose of a kammback is to reduce the amount of drag by to eliminating surface area.
IF you want it 'cause it looks cool, GO FOR IT, 'cause it's not hurtin anything significantly
IF you're justifying the purchase by saying it'll save you gas, it will probably take like four years to pay for itself if it even helps at all
=P
IMO it looks pretty cool.
Old 06-11-2008, 12:07 AM   #8 (permalink)
Thanks for the input. If i find a used one I'll try to get it.... they seem really rare.
Old 06-12-2008, 05:35 PM   #9 (permalink)
Mugen Wing
My thought is that since it's Mugen,it was built for "performance".Since it has no up-sweep it should not induce drag and my guess is that they're using it to move the low pressure wake underneath it to create a little downforce,without the drag penalty.Since it increases the fineness-ratio a tad that's also not bad.It's a perfect fit,it doesn't block your vision,could show a smidge better on fuel,I'll vote,keep it!
Old 06-12-2008, 09:48 PM   #10 (permalink)
Thanks, but i haven't got it... only thinking of getting it, only if i get a good deal
Which CRX? seanof30306 EcoModding Central 8 02-10-2009 05:52 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
non-op '85 CRX, or '91 civic hatchback SirKeats EcoModding Central 1 05-16-2008 04:21 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 12:16 PM
CRX HF transmission swap paulwelkins EcoModding Central 2 02-02-2008 05:52 AM
