Old 06-23-2013, 08:31 PM   #1 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Debating on P/S delete.
I have a 99 Camry 2,2 automatic and I'm debating on removing the belt to my power steering pump. I've read some info on it already if I do it I'm just removing the belt not the pump in case I want to go back to it. I'm trying to get to 40 mpg so far my best tank is 35. Will the p/s delete net me least 1 mpg? more or less? Its should only take about a half hour I have to jack the car up remove tire and the other belt as the p/s belt is behind it. I've also been looking for a shorter belt to bypass the a/c come fall but not luck as of yet. Most vehicles were available without a/c so a shorter factory belt should be available. Thanks for any input.
Old 06-23-2013, 09:19 PM   #2 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
I haven't noticed a differance in fe with my Celica, though I have not done any serious testing. My car is light enough that I don't need power steering, but my truck is. Removing the belt is a good idea to try it out.
Please report your findings.
Old 06-23-2013, 09:26 PM   #3 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
if it is as reversible as putting a belt on or off, just try it. it will undoubtedly reduce fuel consumption. i think its more a matter of how you like driving the car w/o p/s, whether you save .5 or 3.5 mpg
Old 06-23-2013, 09:28 PM   #4 (permalink)
Will do! Wish I had a scan gauge to really see the numbers hopefully soon! Yeah I have a 400 mile trip coming up next month and I'm trying to do what I can to try and get close to 40 mpg
Old 06-23-2013, 09:29 PM   #5 (permalink)
Yeah I don't think it will bother me but if I don't see at least 1 mpg I'll probably put the belt back on.
Old 06-23-2013, 09:30 PM   #6 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 44.87 mpg (US)
I have no trouble engine off coasting through a parking lot, even when steering lock to lock. The steering would be even better if I disconnected the pump and looped the hoses. I'll probably do that someday if I get serious about getting my summer average up to 40 MPG.
Removing the belt from the A/C won't save anything because the pulley freewheels when the A/C is not on. Many cars will automatically turn the A/C on when you select Defrost, however that can be defeated by a fuse pull.
Old 06-23-2013, 09:50 PM   #7 (permalink)
Removing the belt from the A/C won't save anything because the pulley freewheels when the A/C is not on. Many cars will automatically turn the A/C on when you select Defrost, however that can be defeated by a fuse pull.[/QUOTE]
You don't think it would help any? So what you are saying is it acts like an idler pulley when the a/c is off? One day I will also delete the alternator then I won't need any belts haha
Old 06-23-2013, 09:53 PM   #8 (permalink)
JRMichler's Avatar
Right, the A/C clutch pulley is just an idler when the A/C is not being run.
And other people have done alternator deletes to the last little bit of MPG.
Be careful about removing belts, your engine NEEDS the water pump.
Old 06-23-2013, 10:23 PM   #9 (permalink)
I don't think my water pump is run by a belt. One belt has a/c and alternator and the other has p/s only
Old 06-23-2013, 11:15 PM   #10 (permalink)
Team Saturn
If it didn't bother you at all, why put it back on if it only saved a tenth of a mpg?
Without doing an a-b-a test I don't think i would be able to spot a 1mpg improvement. without any other changes my mileage has changed about 5mpg this summer vs last winter
