Old 10-28-2011, 01:12 PM   #31 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
Amazon.com: overrunning clutch: Automotive
Old 10-28-2011, 01:28 PM   #32 (permalink)
Quasi-Modder
Originally Posted by CFECO View Post
For a simple differential just put a overrunning clutch at each wheel.
Would you trust you life to a set of these going 70MPH?
Old 10-28-2011, 01:33 PM   #33 (permalink)
Originally Posted by JRMichler View Post
Neato! How do I attach that to my wheels?
Old 10-28-2011, 09:00 PM   #34 (permalink)
JRMichler's Avatar
Beats me. I'm not about to waste time trying to invent around a differential. But if somebody really wants to build something using overrunning clutches, they are available.
Old 10-28-2011, 10:07 PM   #35 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
I figured I'd get a comment on that! I would hope a professional automotive engineer would not have a problem solving a small detail like that? Hilliard Corp. has bi-directional, industrial overrunning clutches. Building a drive setup with these will also produce a locking diff. action, much like a Detroit Locker. If my drawings were not lost off my previous computer, I'd show you in detail how to mount them too.
Old 10-28-2011, 10:19 PM   #36 (permalink)
Splicing it into the CV shafts probably isn't too big a deal.
I do like the one-way overrunning clutch though- imagine the nice effortless glides! IIRC the old 2-stroker Saabs had them.
Old 10-29-2011, 07:41 AM   #37 (permalink)
Are these essentially ratchets; like in bicycles? Would this eliminate the need for the differential, and how would the efficiency compare?
Old 10-29-2011, 08:11 AM   #38 (permalink)
Plymouth had freewheeling in the 1930s. Caused most of the archaic laws about illegal coasting in neutral passed late in the 1930s.
The problem was you had to be stopped to disengage the freewheeling and the period braking systems were pitiful compared to modern discs.
regards
Mech
Old 10-29-2011, 08:41 AM   #39 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
They use rollers which ride up ramps to lock the inner drive member to the outer driven member. This one works in either direction. Efficiency should be better than a normal right angle differential using gears.
Old 10-29-2011, 09:13 AM   #40 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Are you referring to normal driving or coasting?
I ask because the gears inside the differential don't move that much, and consequently can't be a source of significant losses. During coasting however, you'd have fewer parts moving with freewheeling clutches far out in the drive line.
