10-28-2011, 01:12 PM
#31 (permalink)
10-28-2011, 01:28 PM
#32 (permalink)
Quasi-Modder
Originally Posted by CFECO
For a simple differential just put a overrunning clutch at each wheel.
Would you trust you life to a set of these going 70MPH?
10-28-2011, 01:33 PM
#33 (permalink)
Originally Posted by JRMichler
Neato! How do I attach that to my wheels?
10-28-2011, 09:00 PM
#34 (permalink)
Beats me. I'm not about to waste time trying to invent around a differential. But if somebody really wants to build something using overrunning clutches, they are available.
10-28-2011, 10:07 PM
#35 (permalink)
CFECO
I figured I'd get a comment on that! I would hope a professional automotive engineer would not have a problem solving a small detail like that? Hilliard Corp. has bi-directional, industrial overrunning clutches. Building a drive setup with these will also produce a locking diff. action, much like a Detroit Locker. If my drawings were not lost off my previous computer, I'd show you in detail how to mount them too.
10-28-2011, 10:19 PM
#36 (permalink)
Splicing it into the CV shafts probably isn't too big a deal.
I do like the one-way overrunning clutch though- imagine the nice effortless glides! IIRC the old 2-stroker Saabs had them.
10-29-2011, 07:41 AM
#37 (permalink)
Are these essentially ratchets; like in bicycles? Would this eliminate the need for the differential, and how would the efficiency compare?
10-29-2011, 08:11 AM
#38 (permalink)
Plymouth had freewheeling in the 1930s. Caused most of the archaic laws about illegal coasting in neutral passed late in the 1930s.
The problem was you had to be stopped to disengage the freewheeling and the period braking systems were pitiful compared to modern discs.
regards
Mech
10-29-2011, 08:41 AM
#39 (permalink)
CFECO
They use rollers which ride up ramps to lock the inner drive member to the outer driven member. This one works in either direction. Efficiency should be better than a normal right angle differential using gears.
10-29-2011, 09:13 AM
#40 (permalink)
Eco-ventor
Are you referring to normal driving or coasting?
I ask because the gears inside the differential don't move that much, and consequently can't be a source of significant losses. During coasting however, you'd have fewer parts moving with freewheeling clutches far out in the drive line.
