Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-29-2013, 05:36 PM   #131 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
If you truly want to sell DiamondLube to truck fleets, do the following:
1) Remove all snake oil content from your web site. That includes the phony patent applications, the race car, the 35% MPG gains, everything.
2) Replace with actual facts:
A) A PDF copy of the 1.95% MPG gain report. And no whining about it.
B) Some of the papers discussed earlier in this thread as background. Explain the similarities and differences of your product. Get help from a real engineer.
C) The Nissan patent. Then some discussion as to exactly why your product does not infringe. Get help from a real patent attorney.
3) Then, yes, offer a free kit for their evaluation. Your goal should be to get at least ten kits into the hands of people who can properly evaluate them and communicate the results. These kits will be free to the recipient.
Old 12-30-2013, 06:46 AM   #132 (permalink)
The Facts are already posted.
Old 12-30-2013, 09:15 AM   #133 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Great! But you skipped:
Then run spell check. It'll help.
Transmission type Efficiency
Old 12-31-2013, 07:35 AM   #134 (permalink)
People are told all the time, If it sounds too good to be true it's probably not. The people saying things like that like everything the way it is, and blindly believing narrow minded statements like this keeps you right where they want you.
There are many snake oils out there, and they have one thing in common - they go to great lengths to NOT mention exactly what is in the magical elixir.
Why some people insist on calling Nanotechnology, snake oil is beyond my grasp, however the US Army does not certify Snake Oil for use by our troops therefore it cant be snake oil.
The data on the site is true and will not be deleted, and I suggest those interested in technological advances start reading some scientific literature on nanotech and get up to date. OTOH, you can keep adding Lucas to your engine instead of engine honey and tell all your friends how progressive and green minded you are.
Old 12-31-2013, 08:19 AM   #135 (permalink)
Rat Racer
Originally Posted by DiamondLube View Post
..the US Army does not certify Snake Oil for use by our troops therefore it cant be snake oil.
That is so willfully ignorant that it doesn't even belong in the Unicorn Corral.
Old 12-31-2013, 08:34 AM   #136 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
People dont run Lucas to be "green minded" not sure where you got that from. I've actually seen Lucas unstick tapping lifters on several occasions in customers engines so it does its job. (and I can actually see results, that helps the credibility along )On one occasion the customer changed the oil several times within a couple weeks. They added some cheap oil additive with no success. I changed it once with one bottle of Lucas and it was quiet as a mouse within 3 miles.
Burn lean and prosper \\ //
Old 12-31-2013, 02:53 PM   #137 (permalink)
That supports my Lucas point.
Happy New Year to everyone, including those that don’t believe a word of this.
$85,000 swing bridge (repair estimate) repaired with one application of my Diamond Coating
Various things treated with my Diamond Coating
How only a diamond Coated bearing reacts vs beloved Grease
Independent test showing 30% increase in efficiency on a steam engine
Chris Arnold
Old 12-31-2013, 03:11 PM   #138 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Originally Posted by diamondlube View Post
independent test showing 30% increase in efficiency on a steam engine
how do you measure efficiency without measuring fuel consumption v/s power?!? Omg you are not getting it!!! Making an engine spin faster means it is moving more working fluid!!! That is not a measure of efficiency so stop talking!!!
Old 12-31-2013, 03:23 PM   #139 (permalink)
P-hack's Avatar
stop punishing us with your spam, is there someone else there we can talk to?!? You obviously have no idea what you are talking about.
The Following User Says Thank You to P-hack For This Useful Post:
ecoTex (01-01-2014)
Old 12-31-2013, 04:08 PM   #140 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Aa thin coating of a low viscosity substance verses thick grease does not show anything new nor groundbreaking. You could show the same thing with a clean bearing and one filled with peanut butter.
so a steam engine spins faster at 0 load, neato. Now put a working load on it, will it pull a 30% bigger till at the same speed on the same throttle setting, or plow 30% more fields before running dry?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
