04-15-2011, 11:30 AM
#71 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
With some measurement and eyeballing, and a six pack or two, I'm fairly certain that the twinstar chaos is just too damn small. However, I have an alternate plan that will probably take longer...
I have a yamaha xs1100 parts bike with a good frame, swinger, wheel, and shaft drive... So now I'm looking for a totaled very small car, either fwd or rwd, doesn't matter, with a good front end. That kinds puts metros out of sight. Maybe a really rusty civic... Or an old bug front end.
04-15-2011, 03:05 PM
#72 (permalink)
What about a Festiva/Aspire?
04-15-2011, 03:08 PM
#73 (permalink)
needs more cowbell
Where you going with this Christ? is it still a mcycle? a trike?
04-15-2011, 03:37 PM
#74 (permalink)
Dave, I'm really not sure. The above thought was reverse trike, but mc is still nagging me, as well. Disappointed on top of all because I made it to the glen too latetoday... Really not my day...
04-15-2011, 03:41 PM
#75 (permalink)
needs more cowbell
I LIKE the reverse trike idea, but not @ 10hp
04-15-2011, 03:59 PM
#76 (permalink)
Generally, I was thinking that a reverse trike could weigh nearly the same, but have a much lower cd.
Help out with something? I have a belt driven 33lb/hr pump... Thinking about adding it to the motor, but not sure how to determine if it will move enough air to be worthwhile.
04-15-2011, 04:35 PM
#77 (permalink)
needs more cowbell
no clue, need to know psi too and pump efficiency.
Try Ecofriendly DIY Home Projects
04-15-2011, 09:04 PM
#78 (permalink)
Lol it's a smog pump from a ford 302.that's all I know about it.
09-21-2012, 01:01 PM
#79 (permalink)
Any updates? Ever finish the bike? Still a work in progress?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
09-27-2012, 06:12 AM
#80 (permalink)
Depends. If you consider CO2 a pollutant, diesel always decreases it. If we're talking particulates and NOx, that's an issue, but if you use very little diesel, it becomes a very small issue. And even smaller when you start going into water and urea injection.
