Old 09-29-2008, 07:09 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
Exclamation A different style of Kammback & mounting discussion
could this be done for a hatchback?
you could imagine a flat clear plastic Plexiglas sheet spoiler coming up from somewhere near the wiper base. it could be supported by the wiper base, sealed at the bottom by duct tape to the car and supported at the top by coat hanger wire run from the hatchback hinges.
this would be much easier to make than a kammback?
maybe you would need a baffle running down the middle to guarantee non-separated bubble formation.
i apologize for crude photo-shop and poor image quality.
Name:	Dsc00738 mod spoiler.jpg
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 09-29-2008, 07:22 PM   #2 (permalink)
annotated
its just two coat hanger wires on the corners of the car that support the spoiler at the top. there is no roof to it and the non-separated bubble flow is used to change the effective angle of the rear taper, which would in effect follow the angle of the wire.
Old 09-29-2008, 07:59 PM   #3 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
Two issues with the "Bubble Dam" spoiler that I can see.
A: What about flow from the sides of the vehicle into the bubble.
B: Doesn't the truck bed argument apply to this? (Tonneau better than open bed, tailgate up.) If this is the same, I should just build up the edge of my truck bed to get a 12 degree angle from the cab top.
P.S. Wouldn't you be putting a LOT of force on the Plexi panel? Even with .1 psi, that is 100 pounds of force.
Old 09-30-2008, 10:32 AM   #4 (permalink)
you could cover up the sides no problem there. i have no idea about forces though. might just have to try it and see if it brakes.
Old 09-30-2008, 10:38 AM   #5 (permalink)
if you cover up the sides it looks like a normal kammback thats been put on upside-down! perhaps some one could try this? it looks to me, like a short kammback would be more effective in this configuration than in the normal one because look at the relative lenghts of the orange and grey lines in my diagram
Old 09-30-2008, 12:30 PM   #6 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
This reminds me of the Car & Driver Crisis-fighter Pinto. They added a 6-inch spoiler to improve the flow over the rear glass. It would be interesting to see the difference between a shorter and longer device.
-Terry
Old 09-30-2008, 12:52 PM   #7 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Chevy Metro LSi
90 day: 48.88 mpg (US)
What are some prices on plexiglass? I've been looking around and found some that I think would work or Ebay, no luck locally yet.
Old 09-30-2008, 01:12 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
FunkSkunk -
In the size that I would need for a single piece, it seems like about $40 at OSH.
CarloSW2
American Solar Energy Society
Old 09-30-2008, 07:23 PM   #9 (permalink)
heres my latest optimized spoiler plan. optimized for minimum material, maximum effect and to maintain driver visability.
Name:	Dsc00738 spoiler mkII.jpg
Old 10-21-2008, 09:32 AM   #10 (permalink)
Originally Posted by ac7ss View Post
(R.E rear plexiglas spoiler)
you are right about the forces. i just found the plexiglas at my local hardware store and it was way too flexible to be a spoiler. on the other hand it could make a kammback.
i was thinking... can the plexi be heat bent round by 180* to form a hook to latch on to the hatchback like a cycle carrier? if so this would make for an easy mounting, may not even need the duct tape!
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 256 09-11-2013 04:22 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 06:07 PM
