06-10-2012, 10:38 PM
#41 (permalink)
I never thought about valve lash, ive messed with it on my go cart about 10 years ago. Got more torque with them slightly loose. Good idea...
06-10-2012, 10:41 PM
#42 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
Originally Posted by ksa8907
please, don't neuter such an amazing engine. if you want more torque, port-match the intake and exhaust and maybe try an intake plenum from a charger/challenger.
I'm not sure such a plenum would fit. I'd have to do... things to the firewall, probably. The reason I'm using a humungous Pacifica manifold is because it's the only one that'd fit the engine without resorting to major car body surgery.
06-10-2012, 10:50 PM
#43 (permalink)
Master Ecomadman
If you are looking to gain MPG, then disabling all 8 valves on 2 cylinders would increase it about 20%.
- Tony
06-10-2012, 11:46 PM
#44 (permalink)
Fusion - '16 Ford Fusion Hybrid SE
Really? Where do you get that number from?
06-11-2012, 12:13 AM
#45 (permalink)
MPGuino Supporter
That's in line with what can be expected from deactivating 1/2 the cylinders in a given engine.
06-11-2012, 02:10 AM
#46 (permalink)
That's what I figured.
I thought DOD engines were really complicated. Turns out, they really do just turn valves and fuel injectors off on deactivated cylinders.
06-12-2012, 07:32 AM
#47 (permalink)
Master Ecomadman
I got it from my 1977 Honda Accord, which had a carburetor, 40 to 48 mpg. Slower acceleration than a semitruck. You might have to get two injectors from the junk yard to plug in to keep things happy. My car idled twice as fast. The HF engine and transmission would be better.
- Tony
06-12-2012, 08:19 PM
#48 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Got 'em.
01-23-2013, 12:07 AM
#49 (permalink)
To the OP: Just wondering if you have any updates concerning your 8-valve modification. I was thinking of doing something similar, but I have two questions.
1. Where did you find the spacers for the missing rocker arms? I can't seem to find them on any HF parts catalog.
2. Are there any issues with fuel buildup behind the inoperative intake valve? Upon researching, it looks like the VTEC-E setup actually opens the 2nd intake valve a very small amount just for the purpose of keeping fuel from pooling on the valve.
Thanks for any info!
01-23-2013, 02:59 AM
#50 (permalink)
Too many cars
The spacers are shown here:
http://www.hondaautomotiveparts.com/...E+-+ROCKER+ARM
#8 and #9 in the diagram. It's a little confusing since Honda strangely included 16 rockers in the HF diagram.
Looks like they might not be available anymore. I got mine from a junkyard. The 1992-1995 CX should have them as well. Or find a pipe with the same inside diameter as the rocker shaft diameter and make your own!
If there's fuel building up behind the valves, I haven't noticed it. I've got something like 5000-6000 miles on it like this, no issues. But you'll never see the top half of your tachometer again!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
