Old 03-04-2010, 12:40 PM   #271 (permalink)
Originally Posted by adamj12b View Post
Hey Dave,
Jacks problem right now is he doesn't have a service big enough that is readily accessible to power the charger that wont cause a tripped breaker or the light dimming!!
Also, right now he only has 48V (4 batteries), but is getting 6 more very shortly.
I dont know how much you have done on your charger already, But I have a PCB of this charger all drawn out in eagle that I will be proto-typing in the next few weeks. Im working on a kit basically that this will be the logic, you supply the power stage which is just a rectifier, caps, IGBT, and inductor.
I could use a beta tester that is local...your only an hour away...If your interested.
-Adam
I have done very little, except for a few schematics and looking up parts at Mouser and my schools stock room. I haven't had my 240v plug (or my 120v plug for that matter) installed yet, but when the electrician returns to finish up our house wiring, I have having those installed next to my EV.
I am interested! I forgot you are so close by! I have been collecting enough parts to build a small 6 AMP prototype, but I haven't purchased anything until I figure out what I want it to do. I think too much, and make things was more complicated than they need to be.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 03-05-2010, 08:26 PM   #272 (permalink)
Ok, so I am in the process of designing my charger, so I have made a list of what I want it to do:
1) 120/240v charging, with automatic current adjustments for those voltages
2) Charge my 96 volt pack
3) Be able to fit in the EV
4) 3 Stage programmable, with shutdown at the end. (my K&W just floats forever)
That's the basic stuff, now I get insane:
5) Monitor each battery in the string
6) Estimate SoC and remaining time to charge batteries
6) LCD status of batteries/charger
7) WiFi Connectivity
Yes, I am looking to install WiFi, ZeroG WIFI/O from Microchip. Being an EV nut, I am always going outside to check my battery voltages, see how the charging is coming along, etc so I figure how sweet would it be if I could have that data streamed to me over the network. I have WiFi at home, and at school where I park (Its a computer engineering facilty, it BETTER have WiFi ) so having that data streamed to my laptop would be sweet. Of course it's a dream, but the more I look up this good Microchip has, it could happen.
Old 03-06-2010, 03:35 AM   #273 (permalink)
jackbauer's Avatar
Well the charger will fullfill all 4 of your requirements as is. Regards battery monitoring I use a Victron BMV602 which can be used to log data to a website and send and receive sms messages to a phone relating to battery parameters. Also can be hooked up to a laptop and download historical data such as deepest discharge etc.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-06-2010, 07:50 AM   #274 (permalink)
Do you have your charger setup to count Ah as they go into the pack? The hardware is already there, so it would just be a software thing to deal with. I'll look up that Victron. I only really need my first 4, but I like to over do things in the long run. Most of the things in my EV are overkill, so an overkill charger would fit perfectly.
Old 03-23-2010, 02:20 PM   #275 (permalink)
apowers's Avatar
I made this charger. It is basically the bonn charger with Paul's motor controller limiting how many voltscomes out. I have recharged 4 times and I am satisfied. I leave the pot all on till the 120 volt pack reaches 144 then I turn the pot down to hold it there till the amps are near 0. At the begining of the charge it starts at 12 amps. It all takes 6 to 8 hours.
Alvin
Old 03-23-2010, 02:35 PM   #276 (permalink)
EVVette - '71 Chevy Corvette Coupe
Alvin
Very Cool!!
Do you have more pictures?
What did you change for the software?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-23-2010, 04:18 PM   #277 (permalink)
apowers's Avatar
I did not change anything. It was the chip from my motor controller with the software from last summer. I was thinking maybe it could control the voltage and other things. I don't write code I'm not sure that I could load someone else's code.
Alvin
Old 03-23-2010, 05:50 PM   #278 (permalink)
PaulH
MPaulHolmes's Avatar
Alvin is amazing!
kits and boards
Old 03-23-2010, 07:56 PM   #279 (permalink)
What are you using for an inductor??
-Adam
Old 03-23-2010, 08:08 PM   #280 (permalink)
apowers's Avatar
I have 2 inductors. The first one is on the ac side ,before the rectifier, that I made from a microwave transformer. The second I got from the forklift and it is on the dc pos side right before it leaves the box. I have no idea what the inductance is.
Alvin
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
