Old 03-26-2010, 05:12 PM   #291 (permalink)
jackbauer's Avatar
I actually used a junk plasma cutter transformer for my inductor. Works great. Measured at about 15mH. I'd be very interested to see the info on your design. I like simple circuits!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 04-24-2010, 07:19 AM   #292 (permalink)
jackbauer's Avatar
Here's a quick video on measuring an unknown inductor. A few people have asked me about this procedure. Hope i got it right
www.evbmw.com
The Following 3 Users Say Thank You to jackbauer For This Useful Post:
iwyze (06-06-2010), MPaulHolmes (04-24-2010), mrbigh (04-24-2010)
Old 06-05-2010, 11:45 PM   #293 (permalink)
Adam,
Did you ever get the schematics to post of Williamson's charger? I would really like to see it if it is available.
Thanks....
Rick
Old 06-06-2010, 04:00 AM   #294 (permalink)
Looking forward to seeing the OpenSource charger become available and integrated into the open BMS and controller. Great work to all those involved.
Old 06-06-2010, 12:20 PM   #295 (permalink)
EVVette - '71 Chevy Corvette Coupe
Hey Guys,
I did get the schematics, But he asked me to wait to post them till he finished the prototype. I believe the prototype will be tested this week or so. I will keep you guys posted with the progress.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 06-22-2010, 07:49 PM   #296 (permalink)
apowers's Avatar
I had a 120 volt pack and changed to a 144 volt pack so the charger I made
would not charge that high from a 110 outlet. I moved some connections
around and changed a capacitor. Now the open source control board is a
boost regulator. The voltage goes all the way 186 volts for balancing
and the amps are contolled with potentiometer. My batteries are 115 ah
so I hold the charge amps at 11.5 . The charger was woking as a taper charge. The amps would start at 11 and taper off fast as the voltage came up. It was slow. Now I have to reduce the amps after bulk charge . This is
much better for opportunity charging. Most people have at least a 15 amp
outlet I can use. The bulk charging part takes less than half the time as before.
Alvin
The Following User Says Thank You to apowers For This Useful Post:
MPaulHolmes (06-22-2010)
Old 06-22-2010, 08:12 PM   #297 (permalink)
PaulH
MPaulHolmes's Avatar
Alvin, you are amazing!
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
apowers (06-22-2010)
Old 06-22-2010, 08:53 PM   #298 (permalink)
apowers's Avatar
No... Thank You Paul.
Old 07-02-2010, 05:43 AM   #299 (permalink)
Hello, I'm new to this forum/thread... Hi everybody
I was just wondering, did someone tried to use the motor
controller as a charger. I think it can be esily achieved
if there is contactor on the (M-) terminal of the motor
wich will cut off and divert the output from the controller to (P-) of the rectified
mains line, and it will share the same (+) as the battery, controller
and the motor. There is current sensor on board, it just needs some
precise voltage monitoring of the battery pack. The rest should be
coded in firmware, two or three stage chraging, constant current, voltage, float
etc...
Also this contactor could be used as emergency cut off, and protection
if contoller fails somehow, like poped to always conductive FET,
Contactor terminals can be wired N.C. to mains rectifier, N.O. to Motor, and common to controller (M-).
Any suggestions?
Old 07-02-2010, 06:59 AM   #300 (permalink)
Hi, again... I've just forgot... the current limiting inductor should be connected in series between the rectifier bridge's (+) and the battery pack's (+)
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
