Old 05-16-2008, 12:15 AM   #11 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
After this season, I've been thinking of moving to a warmer climate for mental health reasons.
Yeah me too.. Actually i recently bought land in Texas.. rarely gets below 32 degrees..
Old 05-16-2008, 11:09 PM   #12 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
I have a late model car ('06 Civic) and I just can't see me putting anything on this car that I made myself.
I'm waiting for a quality-made kit I can buy that has:
1) 2 rear wheel skirts (preferably painted to match)
2) solid wheel covers (at least 2 for the front)
3) a better / lower front splitter (the rubber piece that goes under the front bumper.
The DIYer part comes in when I fasten the bits on.
--- Bror Jace
Old 06-21-2008, 09:31 PM   #13 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I just finished Rear Wheel Skirts v. 1.5
Skirts have coroplast backing for added stiffness (think I mentioned that somewhere up the thread already).
And they're now attached to the wheel arch with 5 home made brackets that were installed without drilling into metal. The skirts can be removed/reinstalled in about 30 seconds. The downside is there are now 5 screw heads around the rim of the skirt - which don't look too bad.
I'll post new pics tomorrow.
Old 06-22-2008, 07:00 PM   #14 (permalink)
Pics, pics, pics:
First of all, here's the back of the skirt with the coroplast attached (contact/rubber cement) to stiffen it more for those hot summer days (when the black plastic was getting pretty soft & wobbly):
Next, on to the new non-drilling-the-car attachment method. A crummy shot of the DIY bracket. It's made from flattened copper pipe, stainless nut, bolt & washers:
Next, the same bracket, shown installed. Another crummy shot - sorry:
I made 6 of those special brackets in total, 3 per side. Once tightened, they're well clamped down and very solid.
The other two brackets per side attach to the lip of the plastic bumper, so I just made simple 90 degree bends in the copper pipe, drilled & bolted them on:
And here's the skirt installed. I'll probably paint the screw heads black:
ID:	999   Click image for larger version
ID:	1000   Click image for larger version
ID:	1001   Click image for larger version
ID:	1002   Click image for larger version
The Following 15 Users Say Thank You to MetroMPG For This Useful Post:
101Volts (03-23-2017), California98Civic (10-14-2011), deejaaa (09-03-2013), EchoBallin (08-20-2022), ECONORAM (05-28-2013), elgecko84 (08-30-2012), Jyden (09-15-2013), mikeyjd (05-21-2013), mpg_numbers_guy (04-29-2018), myrefugeisintheLord (12-04-2012), OG VX (12-15-2014), Piwoslaw (08-30-2010), Sven7 (08-08-2013), TexasCotton (10-14-2013), Weather Spotter (08-09-2010)
Old 06-22-2008, 07:08 PM   #15 (permalink)
YES, those are mud flaps on the back wheels. (*hangsheadinshame*)
They serve as a mounting point for the aft end of the skirts (without them the curvature to bring them all the way to the bumper would be so much that I believe flow would detach anyway).
I'll probably trim the excess off now that the final skirt installation is done.
GalwayBogger (05-31-2013)
Old 06-24-2008, 08:39 AM   #16 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Did you trim off those flaps?
I took my rear flaps down to my shop so I could use the belt sander to clean off the edges I cut with a Stanly knife.
http://ecomodder.com/forum/36034-post25.html
I think they are going to be a good mounting point, if I ever decide my CRV should be wearing skirts.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 11-25-2008, 10:52 PM   #17 (permalink)
TacoModder
mobilerik's Avatar
rik's prerunner - '03 Toyota Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
I really like the copper clips you made. Does that type of clip have a name? Can you buy clips like that anywhere? My tools are not cooperating with me right now, and I could really use clips like that!
So you smashed a copper pipe? Is that 1/2"? How did you drill the holes in it? (I mean what kind of bit?) I tried using copper pipe straps, but it was a lot of work, and they weren't tough enough to hold anything.
Old 11-26-2008, 09:37 AM   #18 (permalink)
Not sure if there's a name, or if you can buy them.
Yes, I flattened a 1/2 inch copper pipe with a hammer and drilled it with a regular bit (copper is pretty soft).
Old 11-26-2008, 09:41 AM   #19 (permalink)
PS - aside from the exposed screw heads offending some people's aesthetic sensibilities, the clips are great. I had the car rust treated earlier this month, and the skirts come off / go back on in less than a minute with this setup.
Old 11-26-2008, 09:59 AM   #20 (permalink)
Fokus - '12 Ford Focus SE
90 day: 32.04 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 18.75 mpg (US)
Did you see much of a diffrence in MPG? By that I mean not a 10 or 15 mile trip, I mean a 200 mile tankfull compared to a 200 mile tankfull?
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
