Old 01-03-2015, 09:20 PM   #81 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
No EGR fiasco
Was your coolant temperature lower on your diesel with no EGR?
Not really, just the same I would say.
A little more noisy, maybe.
Oldbeaver
Mercedes 300 D turbo 1993
Old 01-04-2015, 11:09 PM   #82 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
irrelevent if EGR is not yet active
Originally Posted by COcyclist View Post
On the VW TDI is does help warm up times. The Exhaust Gas goes through a stainless steel EGR cooler which is tied into the coolant loop. As the exhaust gas is cooled it heats the coolant flow.
i would have to check to see if the EGR is active
when cold
if EGR is not active until the engine has reached a certain temperature then the EGR cooler will have zero effect on warm up
remember
the primary function of EGR is to reduce NOX and NOX
does not can not form at low engine combustion temperatures
if active
EGR would NOT enhance the operation of a cold engine
Old 01-25-2015, 02:46 PM   #83 (permalink)
Did you guys just agree and move on?!
Old 01-26-2015, 11:01 AM   #84 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I can add some personal experience to fuel this debate, at least as far as the VW diesel is concerned. I installed this tune Dynamic EGR Control for TDIs - TDIClub Forums from Malone tuning about two years ago. I also put in a higher temperature Stant thermostat and my highway mpg has gone up about 10%. Click on my fuel log.
Everything I read says that diesels like to be fully warmed up and be supplied with lots of clean, cold air. EGR is hot and dirty and has less oxygen. EGR hurts fuel economy in a diesel in my experience.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Last edited by COcyclist; 01-26-2015 at 11:58 AM.. Reason: Autocorrect changes my words to nonsense
Old 01-26-2015, 11:50 AM   #85 (permalink)
EGR hurst fuel economy in a diesel
I can add some personal experience to fuel this debate, at least as far as the VW diesel is concerned. I installed this tune Dynamic EGR Control for TDIs - TDIClub Forums from Malone tuning about two years ago. I also put in a hierarchy temperature Stant thermostat and my highway mpg has gone up about 10% . Click on my fuel log.
Everything I read says that diesels like to be fully warmed up and be supplied with lots of clean, cold air. EGR is hot and dirty and has less oxygen. EGR hurst fuel economy in a diesel.
Hello Cocyclist. You wrote the title of my answer. I agree in general on yr opinion. But would like to have facts to sustain it. Did you make a test with a trip computer installed and on the same tract of road, keeping all conditions "ceteris paribus" but EGR? That is the only valid way. Otherwise it is just a suspition based on a (biased) opinion.
In my car I did the same and the effect was opposite. See my fuel log. I wanted to improve FE, disconnected EGR and FE went worse. There are documented reasons for that. Then I reconnect it back, and FE improved.
One cannot rely on fuel tanks FE to get a valid conclusion. From one tank to another, in 700 km travel, many things may change, such as temperature which affect tires, air density and resistance, road surface which is very important, load (passangers and baggage), slope, traffic, extension of continuous driving (it is not the same to drive 700 km in 7 tracts of 100 km each compared to drive 700 km in 40 tracts of 17,5 km), altitude, to mention a few factors that affect FE. Not to mention driving strategies, which may have a 40% effect. And when you want one thesis to win over the other, conciously or unconciously you can make one to be the champion.
Cooler air input makes sense to me, though. What I wish do is to install a trip computer in my car for testing all this mods properly. After that, I will try to install a EGR air cooler, and see what happen, measuring with the trip computer. Compare FE with and without EGR, etc. Explore and test all combinations.
My plan is to use MPGuino, which I already got, for which I am waiting for a mechanic friend of mine who will come to help me.
Regards,
Oldbeaver
Old 01-26-2015, 10:01 PM   #86 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Oldbeaver, You are correct, my methods are not scientific and as I mentioned, I changed the thermostat at the same time. So it is impossible for me to say which caused the change or if it is the combination of both.
I couldn't tell which diesel you were experimenting with but if I recall correctly some TDI owners have suffered worse mileage by disconnecting EGR without addressing the factory tuning parameters. If you are interesting I can try to find the link on TDIclub.
TDi=fast frugal fun
Old 01-26-2015, 10:29 PM   #87 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Originally Posted by mwebb View Post
The current VW TDi (diesel) system does use a throttle body type flap near the center of the exhaust to increase exhaust pressure to assist EGR at various times as determined by the ECM and the current VW TDi does have a throttle body type flap in the intake, again it is controlled by the ECM and part of it's function is to assist with EGR. Both of these "throttle body" type flaps are drive by wire, there are no "throttle cables" or any mechanical connections to them, the ECM has control using little motors with position sensors on the flaps. The EGR gas flows from a higher pressure area to a lower pressure area as assisted by the ECM
Could this account for increased mileage with an EGR tune in a VW?
TDi=fast frugal fun
Old 01-26-2015, 10:44 PM   #88 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
FWIW, I recently added a Jeep Grand Cherokee CRD to the fleet. Based on my encouraging results with the VW I will probably get a Green Diesel Eco tune in the near future. From their website- "Available power is increased to 250hp and the torque is also increased along with a broader torque curve.
Fuel economy is increased by 2-4mpg.
EGR is eliminated and turbo lag is reduced significantly.
The swirl motor is turned off and no CEL if the motor has a failure (common problem on this application)". Marketing, not science, however I will update if I notice any improvement. I am doing this for long term reliability and to avoid a potentially costly repair
TDi=fast frugal fun
Old 01-27-2015, 08:24 AM   #89 (permalink)
Tdi
Tks a lot. I have TDI Club and I have a TDI car also. Skoda.
I am experimenting with a Mercedes 1993, model diesel turbo, 6 cil in line.
Old 01-27-2015, 02:48 PM   #90 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Oldbeaver, I think this was the thread I was thinking of. http://ecomodder.com/forum/showthrea...eat-19275.html
Right here on Ecomodder. Lots if good discussion about EGR in diesels. Josh8loop's link inspired me to do the hotter thermostat. He also has a 60 mpg gas log.
TDi=fast frugal fun
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 10:43 AM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 09-30-2008 11:11 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
Adjustable EGR guitarterry EcoModding Central 1 04-27-2008 03:04 PM
