04-06-2017, 04:20 PM
#131 (permalink)
If you go the E85 route, check out the water injection threads.
04-06-2017, 07:00 PM
#132 (permalink)
Originally Posted by Sparkeysmall
Ive been wanting to get a 4 stroke dirt bike and put street tires on it. I figure the massive suspension they put on those to fly on dirt has to be comfy on the street.
I remember when a former neighbor traded his Honda CG 125 for a Honda XR 200 (the Brazilian model), and one of the first advantages he noticed was the comfort on poorly-mantained pavement and speedbumps.
Harleys are all paint, chrome, sleeveless leather, apehangers and pipes.
Jap bikes can have it too, at a lower cost while also having an enhanced reliability.
I read somewhere a while back that the rear cylinder got shut off to "cool it down".... then again fuel injection is the most technicalogical thing harley has ever played with since the knucklehead came out.
I will say (as a positive) that there new street line is a step in the right direction... Over head cams and liquid cooling?!?!? WHAAAT!?!?
I haven't heard about that shut-off of the rear cylinder to cool it down, and it doesn't make sense anyways. When it comes to overhead cams I don't really believe they're so great at all, but liquid-cooling is a must for any decent V-Twin with a transversely-oriented crankshaft unless the designers intended it to burn the legs of the rider.
04-07-2017, 11:04 PM
#134 (permalink)
If only there were some way to get an even firing order and get the heads out into the airstream.
What do you mean? Don't the heads in a BMW R-Series aready get out into the airstream?
04-08-2017, 01:37 AM
#135 (permalink)
If only there were some way... is called a trope.
04-08-2017, 10:46 AM
#136 (permalink)
I got it. Anyway, that's another reason why I like BMW motorcycles more than Harley-Davidson, the other one being the shaft-drive.
04-09-2017, 10:39 AM
#137 (permalink)
Volvo-driving MachYeen
id like a shaftdrive as a bike, instead of a belt.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
04-09-2017, 10:51 AM
#138 (permalink)
Eco Sol
I'm a little confused on how this turned into a discussion about motorcycles lol. Where's that truck? I want to see that belly pan!
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following 2 Users Say Thank You to Shortie771 For This Useful Post:
04-09-2017, 08:36 PM
#139 (permalink)
I know. Things can turn around. But different discussion can be beneficial from time to time.
Ive actually had some things come up (mainly rain), Excuses excuses, but it took 3 weeks to officially get the topper done. And it took 2 days from start to finish.
Anyway. Ive got to get some sheet metal and make brackets to hold up the belly. I cant wait to get it done too. This coming saturday (april 15th) i promise
Since ive been riding the bike around ive bested 40 per gal all highway doing 80ish. That ST just loves cruising at 90-100. Rpm at those speeds sits right at the torque peak. Ill have to slow down some and see if i cant get 50+.
"20+ from a gas one ton!? INCONCEIVABLE!!!"
-Every other forum i tried to state my intents...
Total spent on mods. :$440($200 was oil. So take it or leave it)
Total returned from 10mpg baseline :$167
miles since i started ecomodding :3315 miles
04-09-2017, 08:43 PM
#140 (permalink)
Eco Sol
I'm just giving you a hard time. I know things take time and life often gets in the way any time we decide to make plans. Glad to see you're planning things out. Can't wait to see what you come up with. Don't forget to take plenty of pics. Keep up the good work.
CR-Z Current Mods:
Max Sidewall PSI
The Following 3 Users Say Thank You to Shortie771 For This Useful Post:
