Old 12-18-2008, 02:48 PM   #21 (permalink)
tires
Originally Posted by Christ View Post
Let's not forget that tire sizing is a factor in overall drive gearing, and might be a cheaper alternative than actually swapping gears in your vehicle, especially as a "test" setup, where the result might not be optimal.
Right! The issue of clutch-slipping at dead starts with manual transmission cars might defeat"life with taller tires",although it is sure an economical way to investigate gearing.
Old 12-18-2008, 03:44 PM   #22 (permalink)
90 day: 51.82 mpg (US)
The challenge in going to significantly taller tires is that they also raise the vehicle height, so you're changing 2 potentially important variables, even if you manage to hold width and rolling resistance constant.
Old 12-18-2008, 04:31 PM   #23 (permalink)
challenge
Yep,I don't want to even go there.I mentioned elsewhere to some member that I'd have to change the shackles or re-arc the leaf-springs to restore original ride-height,and then I'd still lose all kinds of clearance inside the wheel house.I wouldn't be able to climb grades without down-shifting,acceleration on freeway on-ramps would suffer,"passing" would be an issue,it just goes on and on!------------------ The Tremec 6-spd trans is something I'll think about.-------------- An engine swap is intellectually a delicious thing to think about also,although intimidating, considering the truck is daily-driver and used in construction/work/income.
Old 04-23-2009, 10:09 AM   #24 (permalink)
OurInsight - '06 Honda Insight
Great thread. Sure helped get my thinking back on track after being led well into the wilderness by another well meaning soul. Thanks Aerohead for the great summary in post #19 - ironic since it was post #19 from another site which led me off track in the first place ;-)
Old 04-23-2009, 12:56 PM   #25 (permalink)
Kayak hauler - '05 Mitsubishi Lancer ES
90 day: 33.88 mpg (US)
When adding larger tires, remember to change the gears for the speedometer and odometer. I got three speeding tickets in 2000 within two months after going to one size larger tires because it through my speedometer off by 5 mph (e.g. 74 mph on speedometer =79mph shown on last ticket). I assume this would also throw off the odometer (1 mile could = 1.1 miles).
Old 04-23-2009, 02:17 PM   #26 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Yes, at least it does on mine. I am running 155/80/R13 (instead of the 155/70/R13 recommended since they are no longer easy to find) and my speedometer and odometer are both off. On my drive into work this morning the GPS said I traveled 14.08 miles, the odometer said 13.3. Over a 350+ mile trip the GPS and ODO were off by about 5.6%.
Old 04-23-2009, 08:06 PM   #27 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
MazdaMatt noted:
“…Lower TP at the same RPM puts your engine in a less efficient point on the BSFC chart?”
Big Dave comments:
Absolutely true for an Otto-cycle engine. Maybe not true for a diesel. Diesels do not have throttles and hence have flat torque curves and very large BSFC ”islands.”
Even with a gas engine, sometimes the loss of BSFC is less than the overall fuel burn rate so you still get an improvement in MPG, just not as much as the proportional reduction in drag would indicate.
This increase in BSFC is the nugget of truth in the old urban legend of driving at higher RPMs gives better MPG.
If you can achieve a reduction in CdA, then the correct follow-up is to re-gear to keep yourself in an efficient range at the desired road speed.
As I keep saying, gearing is (like aerodynamic improvements) a powerful tool for the real seeker of MPG.
Larger diameter wheels/tires are counter-productive and by no means a substitute for changing gearing. Larger diameter wheels add heights and frontal area and worse yet, add rotational inertia. If bigger wheels improved MPG, then all the "Bigfoot-Wannabe" lifted trucks should get terrific MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 04-26-2009, 11:21 PM   #28 (permalink)
I agree that increased rotational inertia and "in general" larger diameter tires will be counter-productive (for fuel economy), but I wonder if the effect is reduced on a vehicle with a taller ride height.
For example, a 4wd pick up truck has a tall ride height. So I speculate that on a truck with aero mods, increasing the tire diameter slightly (and possibly reducing the tread width), may bring the BSFC back into an efficient island; without significantly increasing the aero due to ride height increase, as there is already so much air traveling under the vehicle in its stock configuration.
Getting down to this level of detail, the amount of rolling resistance a particular set of tires produced would also have an impact. So, some educated tire shopping would be required.
Old 04-27-2009, 08:53 AM   #29 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
thndriia... you goofed your quote. I never said that.
Old 04-27-2009, 03:26 PM   #30 (permalink)
My apologies. That was my first post on this forum, so I'm still working out the details.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Aerodynamics Seminar #2 - by Phil Knox MetroMPG Aerodynamics 2 05-10-2013 05:34 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Drag reduction - A new theory? AXMonster Aerodynamics 12 12-18-2008 02:16 PM
aero-mods,installment#9(internal drag) aerohead Aerodynamics 39 07-11-2008 05:45 PM
