Old 01-16-2013, 12:31 PM   #191 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by serialk11r View Post
t vago, you're forgetting that in order to produce the same amount of power, the manifold pressure needs to be higher.
Yes, this is about throttle loss in particular. 'Pump cycle losses' as t vago discussed will increase or be about the same with DCD but throttle losses will decrease.
Originally Posted by t vago View Post
Since DCD only cuts out a cylinder once per firing cycle, intake manifold vacuum never gets a chance to significantly lower,
Not true.
My argument in #185 was elegant and perfect. I can quickly rephrase it and simplify it even further: You only have to believe three principles:
1) DCD results in higher air mass per cylinder per revolution to produce same torque with fewer combustion cylinders. This is a fixed AFR system, where DCD requires more fuel per combustion cylinder per revolution.
2) Higher air mass per cylinder requires higher throttle position. That's how the throttle works, by design. If that correlation isn't there, then just remove your throttle and drive without it.
3) Throttle loss dominates over 'pump cycle loss' (defined between intake and exhaust valves as t vago illustrated). If this were not true then lean-burn would not work. It is exactly the same.
Old 01-16-2013, 12:31 PM   #192 (permalink)
I ain't near edumacated enough to follow all that graph stuff, but, I suspect that this is not such a good idea.
Yes, pumping losses go down as you now have an engine that is running like crap and you have to open the throttle further, but, you also have lost the benefit of getting power out of cylinders that are every bit as much a drag for 3/4 of the combustin cycle as they were when they were firing.
I do wonder if this idea might work given sophisticated enough engine control. What I mean is that lets say every X cycles a lean shot is applied followed immediately by a blank cycle. The lean firing got things a little warmer than normal, the dud then cools it off.
I suspect this causes emissions issues, but might be a way of getting the benefits of lean burn without melting holes in your pistons.
Old 01-16-2013, 01:33 PM   #193 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Well, true-believers, go ahead and give this a try. Nobody's really stopping you from attempting to turn pi into exactly 3, make water run uphill, or make this DCD idea work.
Throttling losses are actually a fairly minor component of pumping losses described here. You can define throttling losses are the aerodynamic losses incurred by trying to push air past a really huge aerodynamically ugly shape (the throttle plate).
Lean burn works precisely because it causes intake manifold vacuum to lower. It takes a rather large amount of energy to create a vacuum, and it takes an even larger amount of energy to create and maintain this vacuum in an open system such as an intake manifold.
Throttle opening controls intake manifold vacuum, but it is not of primary importance.
and wrong.
Are we talking real-world, or are we talking religion? Belief has nothing to do with this - in the real world, things either work or they don't. All the belief in the world won't change that.
This is an observation. So what?
No, higher air mass per cylinder requires lower intake manifold vacuum. That's how a basic Otto-cycle internal combustion engine works, by design.
Oh, and I think that BMW did away with the throttle body altogether, and they still manage to effectively vary the air mass per cylinder in their engines. However, even BMW could not get rid of throttling altogether - their engines that lack a throttle body still have throttling losses.
The throttle only controls intake manifold vacuum. It is intake manifold vacuum that actually controls the amount of air going into the cylinders, and it is intake manifold vacuum that is represented in those graphs.
Don't confuse the two. You could have the most efficient throttle in the world, with zero aerodynamic drag, and zero throttle losses, and you'd still have to put up with intake manifold vacuum, which represents the pumping losses you so cavalierly dismiss.
3) Throttle loss dominates over 'pump cycle loss' (defined between intake and exhaust valves as t vango illustrated). If this were not true then lean-burn would not work. It is exactly the same.
And... how is that "pump cycle loss" defined in that graph? The area created by the volume difference of the piston in the cylinder, multiplied by the pressure difference between the intake and exhaust manifolds?
Sound familiar? And why is there a pressure difference? It's the pressure difference that matters, not the fact that there is a throttle. As stated before, BMW managed to get rid of the throttle plate altogether - however, there's still throttling going on, with all of its losses associated with throttling air flow. The fact that they can still produce more efficient engines in this way shows that there is something besides throttling losses to consider.
Also, do you know how much power is needed to maintain a 7 psig vacuum in an intake manifold of, say, 4 liters of volume, at 2000 rpm? It's a bit under 5 HP - just to do this. That's not including the power that's also required to drive engine accessories, overcome powertrain friction losses, or overcome other internal engine losses - let alone the power needed to propel the car forward.
Get my name right. It's not exactly hard to do.
Old 01-16-2013, 02:22 PM   #194 (permalink)
christofoo's Avatar
There are few things I enjoy less in forum than a physics disagreement. I really just want an excuse to leave the conversation, especially one as pointless as DCD.
Impoliteness is the perfect excuse, and I have a low tolerance for it. I think I've been relatively polite up to this point, although I'm often not the best judge in that regard, so if I've been impolite it was unintentional.
There truly isn't a point in proceeding.
Me: EPA will stop DCD, for good reason.
You: It won't work at all.
Let's call it a day.
Sorry. I got it right at least once.
The Following User Says Thank You to christofoo For This Useful Post:
user removed (01-16-2013)
Old 01-16-2013, 07:47 PM   #195 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
If anyone want to know how real cylinder deactivation is achieved here is a video about it.
Note that successful cylinder deactivation requires mechanical intervention. If it was as simple as turning off injectors don't you think manufacturers would have done that from the factory?
Project Avalon: E bike build
The Following User Says Thank You to razor02097 For This Useful Post:
t vago (01-16-2013)
Old 01-16-2013, 09:25 PM   #196 (permalink)
The best cylinder deactivation would be two engines of half the displacement of the one they replaced. Both connected to the same powertrain, with either capable of cruising individually.
regards
Mech
Old 01-17-2013, 09:25 AM   #197 (permalink)
justme1969's Avatar
OK forgive this stupid question but 4 6 8 cadillac engine was first mass produced deactivating system of my knowledge.
This was not a raging sucess was that a cdc or tcd or other???
Old 01-17-2013, 12:23 PM   #198 (permalink)
christofoo's Avatar
EDIT: the ref is not similar, as Frank pointed out.
Emissions suffice to explain why DCD is not done at the factory. This was posted in #179 by Old Tele man:
http://www.epa.gov/otaq/consumer/devices/511817.pdf
Old 01-17-2013, 02:56 PM   #199 (permalink)
^Nope.
Old 01-17-2013, 03:12 PM   #200 (permalink)
razor02097's Avatar
I don't think so. If it were emissions then DFCO wouldn't have been used. There is no way to accurately measure the efficiency of the engine when pumping pure air through the exhaust in an engine running state. That is why variable displacement engines physically hold the exhaust cycle so when the cylinder is active again it can expel the exhaust and intake air and fuel.
Think about it the O2 sensor senses O2. You pump ambient air past it and it will swing crazy lean. The ECU responds by adding fuel to that bank.
