Old 01-17-2013, 06:41 PM   #211 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
This thread didn't die, and I'm still getting foam flecked PM's from t vago, so I want to try delving back into whether or not DCD will improve FE.
But I want to try simplifying my argument again, largely for previously mentioned reasons.
So, here goes:
DCD vs lean-burn: Why does lean-burn work and DCD not?
Suppose the lean-burn engine is operating at 25% (er, how to say this?) leanness, by which I mean stoichiometric AFR X 1.25.
Compare to DCD with 25% of cylinders deactivated, 75% at stoichiometric AFR. All else being equal, including valve timing.
If you think I'm wrong, explain to me:
  1. Is there a difference in air mass flow rate?
  2. Is there a difference in manifold vacuum?
  3. Whatever else you think requires consideration.
Old 01-17-2013, 06:47 PM   #212 (permalink)
Because lean burn does not incur pumping losses.
Old 01-17-2013, 06:49 PM   #213 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
PS, are you saying that you design ICE's for a living? Otherwise don't give me that. Actually, one way or the other, be nice.
Your latest foray into that charlatan's thread illustrates my point rather well. How many edits and "oops" did you do there? Learn more about what you're trying to comment on.
Apparently, in your universe, this counts as "foam-flecked." Alright, prima donna, let's have at it.
So, here goes:
Lean Burn works because intake manifold is lowered, compared to an engine running at stoichiometric. DCD does not work, compared to Lean Burn, because you're placing a drag on the engine (in the form of non-firing cylinders that are still pumping air - therefore consuming more fuel than necessary).
Figure the rest of it out on your own, professor.
Old 01-17-2013, 06:49 PM   #214 (permalink)
christofoo's Avatar
High AFR means extra air, which doesn't contribute to combustion, getting pumped through the engine. Can you elaborate?
Old 01-17-2013, 06:53 PM   #215 (permalink)
christofoo's Avatar
Same number of pistons, same mass of air? (answer the question please?), same RPM. Please elaborate.
Old 01-17-2013, 06:54 PM   #216 (permalink)
I have elaborated in the past. The short version is, pumping air through cylinder(s) in which no combustion takes place consumes power. Ever notice how powerful the motors on air compressors need to be?
Old 01-17-2013, 06:57 PM   #217 (permalink)
christofoo's Avatar
Maybe link to your elaboration? I still don't see how over-stoich-AFR, i.e. pumping extra air through the cylinder that doesn't contribute to combustion, is different. I see an energy conservation argument here.
Old 01-17-2013, 07:02 PM   #218 (permalink)
MPGuino Supporter
t vago's Avatar
Would you agree, christofoo, that the very act of sucking in air into a cylinder counts as work being consumed?
Old 01-17-2013, 07:03 PM   #219 (permalink)
christofoo's Avatar
Agreed. This is also true going above stoich-AFR.
Old 01-17-2013, 07:05 PM   #220 (permalink)
MPGuino Supporter
t vago's Avatar
It doesn't matter whether the AFR is rich, at stoich, or lean. Take as a given the fact that a cylinder has to consume work to suck in air (or an air/fuel mix).
Now, how much work does each cylinder consume? Not looking for numbers, but a general answer.
