Old 05-22-2014, 10:38 AM   #1 (permalink)
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Easy weight reduction. (remove window stopper blocks)
This is something that might be overlooked if you're trying to reduce weight in your vehicle but if you have pretty much any 4 door car this is a good way to get rid of at least 4lbs or more.
You've probably noticed that the back windows of most cars won't roll down fully in some cars this is because of the shape or angle of the door not allowing the glass to fit fully inside the door but in other cars this is because of a stopper block that keeps the windows from making it all the way down. Supposedly this is a safety feature so if you follow the instructions is this and someone falls out your window because of it I am not responsible.
Anyway what you want to do first is a little research on your car to find out if you have a removable stopper or not. If you do keep reading, if you don't know if you do keep reading, if you don't have a stopper sorry this won't help you any.
Next you need to either find out how to remove it online and know what to do or find out how to remove it by taking stuff out of your car until the back window disappears into the door (hint, you'll find what you're looking for in the back door).
Start by removing the door cards every car is a little different but usually there are a few bolts or screws and a bunch or plastic fasteners holding it on. Once that's off you'll have to pull the vapor barrier out of the way I just pull it gently till the adhesive lets go then you can just reseal it when you finish. Now there should be two bolts holding the stopper in so just take them out and then pull the stopper out. At this point you'll want to CAREFULLY roll the window down to make sure it works and won't scratch the glass or anything. If you have no issues with the test roll the window up and down a few more times just to be safe then put everything back together and carefully test it again. If you have no issues then you're done.
Here is a 2 part video that shows how to do this on a cavalier or sunfire you could use it as a reference for the steps in this post if you want.
Part 1
Part 2
The Following 2 Users Say Thank You to backpacker3 For This Useful Post:
ME_Andy (10-14-2014), tyronasauras (10-16-2014)
Old 05-22-2014, 10:50 AM   #2 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
i don't have one.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 05-27-2014, 12:50 PM   #3 (permalink)
topcat's Avatar
Celica VVTI - '05 Toyota Celica GT VVTI
90 day: 41.89 mpg (US)
This is a terrible idea for many obvious reasons.
The Following User Says Thank You to topcat For This Useful Post:
Cobb (10-14-2014)
Old 05-27-2014, 01:28 PM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
.....and how much does a window stopper weigh?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following 2 Users Say Thank You to mcrews For This Useful Post:
backpacker3 (05-27-2014), NeilBlanchard (05-28-2014)
Old 05-27-2014, 02:45 PM   #5 (permalink)
Team Pontiac
Mcrews Mine were about 3.5 lbs a piece they are surprisingly heavy. I know that's not much but it doesn't reduce functionality and I had no use for them they don't affect road noise at all. They were just adding weight for no important purpose and were essentially just dead weight.
Topcat why exactly is this such a bad idea? My front windows roll all the way down. Should I fabricate a stopper for those? I don't know anyone who would be inclined to jump out of the back window because it has an extra 3 inches opened up.
Seriously though there are plenty of cars with back windows that roll all the way down. Jeeps drive around with no top or doors. Plenty of people have done this before without any issue. I actually am interested to hear why you believe this is such a bad idea.
Old 10-13-2014, 10:32 PM   #6 (permalink)
Wink $40 Battery swap
My lead acid waz dead so I went on Egay and found a 12v 20ah battery designed for alarm systems and I gave it a try. I worked well on my civic and should work on most 4 cylinder cars, They also have a larger one that is 12v 30ah if you live in cold climates. going from a 35lb lead acid to a 14lb AGM should make a small difference in stop and go traffic because less force is required to get the car going again from a dead stopp.$40 Lightweight battery - YouTube
Old 10-14-2014, 07:15 PM   #7 (permalink)
Just do what I did and remove the starter.
Old 10-14-2014, 07:54 PM   #8 (permalink)
Not banned yet
deejaaa's Avatar
i checked the vid and ebay. prices are as stated. i am interested in how long they live under the heat/cold/vibes. i will be needing a battery soon so would like updates.
Old 10-15-2014, 09:34 PM   #9 (permalink)
What about removing all the crap for the rear windows and glue them in the up position? Remove the regulator, motor, gearing, stopper? That ought to save 10-15 lbs a door.
Old 10-15-2014, 10:59 PM   #10 (permalink)
Replace the rear windows with sheet metal?
