Old 09-24-2023, 12:43 AM   #31 (permalink)
I get a reading on my psid indicator. If I run the bypass valve wide open, when cold and take it up to about 2,800rpm and I get a slight reading. Yeah I think this filter is going to last a while.
Old 10-10-2023, 04:55 AM   #32 (permalink)
Originally Posted by bwilson4web View Post
From my Prius transaxle oil studies:
  • < 1000 miles - early change to the left over manufacturing crap out.
  • ~5,000 mi - dilutes the residual oil debris from what can's be drained out.
  • follow manufacturers recommendation.
For an engine, I would divide all by a factor of 10 due to higher stress and heat.
Bob Wilson
I'm following this advice
talismani.rs
Old 10-10-2023, 11:53 PM   #33 (permalink)
The stump grinders predator 459cc has bad oil after 10 hours. High iron, high aluminum and high silicon.
The lab couldn't get particle count as the oil was too dirty.
I'm going to throw the filter on there, run it an hour or 2 and retest. The filter I'm using catches 95% of 2 micron particles and 99.9% of 27 micron particles the setup will filter the oil around once a minute. So even after a few minutes, or by the time the engine warms up the oil cleanliness should be greatly improved. Shouldn't be much in the oil bigger than 5 microns after 5 minutes.
Old 09-11-2024, 12:09 AM   #34 (permalink)
Interesting info on the velocity stack oil pan.
Any pics?
I'd love to know what a tuned length exhaust into one of David Vizard's Pressure Wave Termination Boxes does for a 1 cylinder engine, that you want to be efficient AND quiet.
ie: Lots of (free flow?) mufflers; A glass pack for high frequencies and a resonator for low and/or Helholtz or Quarter Wave Resonators. (especially for constant rpm engines) and ???
He gets into them around here:
https://youtu.be/J4w9fmb41Wc?t=1179
Then; if/when one of these engines gets old n smokey and its time for a rebore etc; it'd be great if you experimented with Boric Acid on it so others here actually believe me!
I've spoken on it some around here recently:
https://ecomodder.com/forum/showthre...tml#post695278
And have done it (to unbelievable effect!) AFTER learning all the ins and outs.
Old 11-30-2024, 11:59 AM   #35 (permalink)
To get the most stuff that shouldn't be in the oil out of the oil I found a Baldwin 10 micron hydraulic filter that fits my filter head. Should be grabbing 10 microns at 99% efficiency and have an absolute of 20 micron.
A bt344-s filter.
If you want to filter really small particles out of the oil, the simple trick of sticking a decently strong magnet or 2 on the outside of the oil filter might be worth considering?
It wont do anything for non ferrous aluminum, but will catch the harder ferrous metal worn off of rings, bearings and gears that, being harder, do more damage.
But at the end of the day; a self renewing, chemically inert, layer with 85% the hardness of diamond and the lowest coefficient of friction known to man (in 2007) is what will make your engines outlive you.
https://www.anl.gov/article/nanobori...-more-slippery
But I now get the silence:
Far better to routinely replace engines and buy extra fuel and oil than be a... 'convert', cast out from the herd.
https://ecomodder.com/forum/showthre...-26602-14.html
Old 02-08-2025, 01:26 AM   #36 (permalink)
I have a test board installed for just this type of thing. I allready solved the Vault Mod by making it work properly. Maybe I can install these and see if we can get it to play nice as well, with PCP.
If so, Ill be back in abit with a answer for you.
carburetor
