06-08-2012, 10:24 AM
ecomodding commercial airplanes
How ?
Replace the in-flight entertainment TVs with iPads !
For this carrier it meant a 7% weight reduction - which is a lot on an airplane.
The things are flight-approved, as chances are the crew already use them to store their route-data, approach charts, as emergency back-up flight instruments and what not.
IPads on a Plane Let Scoot Save Fuel by Shedding TV Tons - Bloomberg
06-08-2012, 12:30 PM
NightKnight
Wow!! 7% weight reduction is huge!
06-08-2012, 12:41 PM
Pishtaco
As the comments note, a 777-200 weighs >750,000 lbs, & 7% of that is 52,000 lbs. If the airline flies primarily A-340s, 7% is still 42,700 lbs. The entire aircraft entertainment system only weighs 2 tons, so its removal & replacement with iPads only accounts for a portion of the claimed weight loss.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
06-08-2012, 01:05 PM
If they added the winglets to the wing tips, they could lower the drag somewhat. These truncate the vortexes that form there, because of the higher pressure below the wing flowing up and around the wing tip toward the lower pressure air on the upper part of the wing.
06-10-2012, 02:31 PM
aero guerrilla
Maybe to get the 7% weight savings they removed not only the TV system, but also the seats?
The tablets helped the carrier cut 7 percent off the weight of planes [...] even after a 40 percent increase in seating,
BTW, How much do 400 iPads weigh?
Scoot will charge economy passengers S$22 ($17) a trip to rent the tablets, which are loaded with movies, music, games and television shows.
I bet they'll make more money on that than on saving a mere 2 tons of weight
06-14-2012, 11:25 PM
Bertha - '16 Mercedes Benz Metris
^THAT is really what is going on. Cash money, and their new way to make it.
RETIRED
06-15-2012, 09:54 AM
...beats walking...
...get rid of the passengers and cargo and the plane will fly alot faster and further-per-gallon of jet fuel...but, of course, it won't make any profit either.
06-16-2012, 01:17 PM
heading for 40
The in flight entertainment is more than just those tvs . It is a lot of wiring, power packs, computer systems and routing equipment connectors . I pad is relativly self sufficient.
does my sig work now?
06-27-2012, 06:32 AM
#9 (permalink)
aero guerrilla
Can any plane be retrofitted with those winglets?
06-27-2012, 01:35 PM
#10 (permalink)
DieselMiser
Some how I don't think the 7% weight reduction is off the total planes weight. Its probably a 7% reduction compared to the existing entertainment system. In the aircraft industry a savings of 100 pounds on an airliner is often worth going after.
