Old 06-08-2012, 11:24 AM   #1 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
ecomodding commercial airplanes
How ?
Replace the in-flight entertainment TVs with iPads !
For this carrier it meant a 7% weight reduction - which is a lot on an airplane.
The things are flight-approved, as chances are the crew already use them to store their route-data, approach charts, as emergency back-up flight instruments and what not.
IPads on a Plane Let Scoot Save Fuel by Shedding TV Tons - Bloomberg
Old 06-08-2012, 01:30 PM   #2 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Wow!! 7% weight reduction is huge!
Old 06-08-2012, 01:41 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
As the comments note, a 777-200 weighs >750,000 lbs, & 7% of that is 52,000 lbs. If the airline flies primarily A-340s, 7% is still 42,700 lbs. The entire aircraft entertainment system only weighs 2 tons, so its removal & replacement with iPads only accounts for a portion of the claimed weight loss.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 06-08-2012, 02:05 PM   #4 (permalink)
If they added the winglets to the wing tips, they could lower the drag somewhat. These truncate the vortexes that form there, because of the higher pressure below the wing flowing up and around the wing tip toward the lower pressure air on the upper part of the wing.
Old 06-10-2012, 03:31 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Maybe to get the 7% weight savings they removed not only the TV system, but also the seats?
The tablets helped the carrier cut 7 percent off the weight of planes [...] even after a 40 percent increase in seating,
BTW, How much do 400 iPads weigh?
Scoot will charge economy passengers S$22 ($17) a trip to rent the tablets, which are loaded with movies, music, games and television shows.
I bet they'll make more money on that than on saving a mere 2 tons of weight
Old 06-15-2012, 12:25 AM   #6 (permalink)
Bertha - '16 Mercedes Benz Metris
^THAT is really what is going on. Cash money, and their new way to make it.
RETIRED
Old 06-15-2012, 10:54 AM   #7 (permalink)
...beats walking...
...get rid of the passengers and cargo and the plane will fly alot faster and further-per-gallon of jet fuel...but, of course, it won't make any profit either.
Old 06-16-2012, 02:17 PM   #8 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
The in flight entertainment is more than just those tvs . It is a lot of wiring, power packs, computer systems and routing equipment connectors . I pad is relativly self sufficient.
does my sig work now?
Old 06-27-2012, 07:32 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
Can any plane be retrofitted with those winglets?
Old 06-27-2012, 02:35 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Some how I don't think the 7% weight reduction is off the total planes weight. Its probably a 7% reduction compared to the existing entertainment system. In the aircraft industry a savings of 100 pounds on an airliner is often worth going after.
