05-23-2017, 06:59 AM
#261 (permalink)
Volvo-driving MachYeen
haha, maybe i should heat the springs so they flatten even more, then use riser blocks when i go off-road? ROFLMAO
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
05-23-2017, 11:50 AM
#262 (permalink)
heat ? just use a hack saw to shorten them :P
05-23-2017, 12:22 PM
#263 (permalink)
I don't recommend neither heating or cutting the original springs, since that would change their tension resistence and they could eventually break apart while moving.
05-23-2017, 01:21 PM
#264 (permalink)
that's what i thought of.
05-26-2017, 07:47 AM
#265 (permalink)
lol, the vac gauge stopped working, and shows a constant 0,6.
Found out the hose has melted shut the hose is 30 cm from the exhaust manifold. i must buy something more heat-resistant
05-27-2017, 04:08 AM
#266 (permalink)
What does it have for heat-shielding around the exhaust manifold and the hoses that run too close to it?
05-27-2017, 03:19 PM
#267 (permalink)
the manifold is cast. It has no shielding, everything just goes around the manifold instead- except the vac gauge line i put too close
05-27-2017, 03:55 PM
#268 (permalink)
i wonder if a should go back to the cone-filter.
Looking at statistics, i got the highest MPG when i had the cone filter.
05-29-2017, 01:17 AM
#269 (permalink)
If it didn't affect the performance so much negatively, go for it.
05-29-2017, 07:56 AM
#270 (permalink)
i think it got warmer air thru it. And it was less restrictive.
