Old 03-12-2013, 07:09 AM   #21 (permalink)
mario.silva
try right click on mouse and then "copy shortcut". then paste on browser. Thanks!
Originally Posted by Teemo View Post
Your link do not work. Login window appears.
Can you add link without login?
All the best.
Old 03-12-2013, 07:11 AM   #22 (permalink)
mario.silva
or...
go to google and search:
"clean_and_cool.pdf"
it should be the first link.
Regards.
Old 03-12-2013, 07:53 AM   #23 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Regards.
You could have posted the link.
Click me
Project Avalon: E bike build
Old 03-20-2013, 05:27 PM   #24 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I was thinking about the heat exchangers which cool down EGR gasses with coolant (like in most new turbodiesels): We ecomodders want to run our engines hotter than normal, but then the coolant is also hotter, so there is less EGR cooling. So in a gasser, why not use intake air for cooling? It is almost always colder than coolant, it works like a WAI, and if the HX gets a leak, then there is not too much wrong with some exhaust gasses seeping into the intake.
Old 03-20-2013, 05:59 PM   #25 (permalink)
You don't want to cool the EGR gas down too much so that it condenses. If it does you now have to worry about water in the EGR system.
Old 03-20-2013, 06:22 PM   #26 (permalink)
I think that water is not a problem, but different impurities that accumulate to cooler with moisture and eventually block it.
There you go:
Old 03-21-2013, 07:18 AM   #27 (permalink)
mario.silva
Thumbs up EGR gases cleaning
Maybe a "water bubbling filter" like the guys that run the wood gasifyers have should prevent that...
Old 10-26-2016, 10:31 AM   #28 (permalink)
I'd like to dabble with EGR mods first beginning with EGR cooling. For the sake that i have an archaic 80 car and no cooler. Rather than complicate my cooling system i'd rather have an air cooled heat exchanger by means of tapping the exhaust pipe further down stream.
Should get my egr source at a medium temp in front of the cat or after the cat at the coldest point. I plan to return it to the engine with 5 - 10 feet of copper tubing. I understand it should not be cooled too much.
My main question is should I take advantage of unburned combustibles before the cat or go for max cooling and keep the intake charge dense???
Thanks!
crx hf, egr, exhaust gas, intercooler, knocking, simple way to save fuel
