Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 09-08-2012, 10:47 PM   #41 (permalink)
I guess the grenade-deflecting SUV would need a shield, too, right?
Old 09-08-2012, 10:53 PM   #42 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
You'd always want an SUV or pickup behind you otherwise much of the blast energy will be wasted to the rear and not propel you forward as much as you want.
Heck, Frank, no means of propulsion is 100% efficient. You're always going to have losses.
Old 09-08-2012, 11:37 PM   #43 (permalink)
No. Blow one away and guaranteed within seconds another will take it's place 14" behind you.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
chumly (09-09-2012), some_other_dave (09-10-2012)
Old 09-08-2012, 11:51 PM   #44 (permalink)
This is true, but here at EcoModder we strive to minimize those losses.
Old 09-09-2012, 12:13 AM   #45 (permalink)
Oh fine. I will just give up now.
Anyone want a grenade? I pulled the pin and the handle, but they are still good for a little while.
Old 09-09-2012, 12:04 PM   #46 (permalink)
Mythbusters tried blast-shockwave propulsion with a dummy strapped to a kite earlier in the season. Doesn't work without something to bounce the blast off of. Then again, the dummy was not sitting on the explosive.
Get close enough to make it work, though, and the shockwave will probably kill the driver.
On-topic, just talked to a guy who actually bought one of those turds on a whim. He said it actually did help his carbureted motor. Smoothed out the idle and improved off-idle response. Did absolutely bupkiss after. Exactly what you'd expect from 1 psi or so of boost.
Old 09-09-2012, 12:53 PM   #47 (permalink)
MPGuino Supporter
t vago's Avatar
Well... yah. That's why a 2 inch thick blast shield is needed, along with the shock absorbing mechanism.
Here's another vehicle (okay, it's fictional) that was designed to use shock wave propulsion. Only, instead of hand grenades, it used nuclear bombs.
Old 09-09-2012, 04:48 PM   #48 (permalink)
t vago, you are my hero just for referencing Niven! That sounds like a book that I read a long time ago. It was not a battleship, though, this was the first trip to the moon.
They did a better plan than NASA. Oh well. It was fiction.
Old 09-09-2012, 07:49 PM   #49 (permalink)
MPGuino Supporter
t vago's Avatar
Yah, I generally like most of Niven's work. ("Yah" comes from there, too, BTW). Strangely enough, though, I only really got into his Known Space work. Well, apart from Footfall, that is. And Fallen Angels. Okay, those two were in collaboration with Pournelle.
Old 09-09-2012, 08:06 PM   #50 (permalink)
It is okay to go off-topic in this forum, right?
Pournelle is another good one.
