Old 04-15-2013, 09:39 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
It's not the best idea to cut the fuel before injector pump. It will force pump to run dry before engine will die.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-15-2013, 09:54 AM   #12 (permalink)
AndrzejM's Avatar
I just have an idea... What about a very strong magnet on the top of solenoid? Then some kind of device that will move it up and down to open and close valve.
You may try to put a magnet over solenoid then disconnect cable and see if the engine will die or not.
Just a thought but that can actually may work IMHO.
Old 04-15-2013, 10:42 AM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Anyone using magnets to increase milage?
Old 04-15-2013, 01:53 PM   #14 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
If you defeat the solenoid, how will you shut the engine off? That question must be answered first.
An upstream valve will starve the pump and not shut off well. You would have to re-design the pump solenoid to shut off on the application of power, like with a push button, so once the engine is off, you can release it to not draw on your battery.
Seems like a lot of work to save less than 30 watts. Defeat your daytime headlights and save more than that.
I'm not coasting, I'm shifting slowly.
