Old 08-31-2010, 11:09 PM   #1 (permalink)
aerobrick - '04 Dodge Dakota Quad Cab SXT
engine mods worth doing?
I read in several of the threads that you should use the thinest oils that OEM recommends and use synthetics for engine oil .. transmission .. rear differential. Someone elsewhere also mentioned and showed a picture of a special four sided grounded side sparking spark plug but that might need to have special valves or something for those plugs. But this got me thinking. Are there any recommendations for eco mods for engine fuel efficiency that actually work .. magnetic fuel line mod is supposed to be a hoax .. but do any work like they say. High flow air filters do anything. I am going to replace my tires soon and as I don't go off roading .. going to see if I can find a LRR passenger tire for my truck (would love some recommendations for tires too).
Just filled second tank since attempting to mod the driver ... no changes even though I am trying. The good news is that my truck actually gets the MPG the dealer said it would. (or is that bad news?)
Don
Old 08-31-2010, 11:43 PM   #2 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
There are a few engine mods that actually work, most take considerable time though.
the proven list of mods is here if you haven't previously come across it there is an engine/drive train section
65+ Vehicle modifications for better fuel economy - EcoModder.com
The wiki has data for only a few of these mods
Car Modifications Main - EcoModder
One user suggests Synthetic oil give no gain larger than 1% on MPG
Alternator delete can give up to 10% but there are obviously come consequences to this mod
In the unproven section of the wiki I have put a few in which I know without any doubt have worked for me.
Car idle reduction and cold start idle reduction but there are also some consequences to these mods as well.
Good luck
Old 09-01-2010, 12:09 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The botch +4 plugs that you talked about don't seem to work well for Japanese engines but from what I read do work on some American style engines (valve lay out, combustion chamber shape) the SAE (society of automotive engineers) publishes books and papers, some libraries can get these, they are well worth the read as they are peer reviewed papers based off of real research and testing, they cover alot of questions about exhaust size, spark plug style, combustion chamber shape, tires, fuels, oils, the list just goes on and on! but their info is not free, they sell their research papers, so there isn't alot to find for free on the internet, but it's all solid info.
Basic their only oil viscosity is that you need to keep your oil pressure up to protect your bearings, the thiner the oil is the easier it flows out of the bearing, most cars don't have oil pressure gauges any more and the pressure switch is just an on/off pressure switch.
Air filters are a hot topic of debate as well, but it really comes down to the amount of air going in to the engine has to burn a set amount of fuel, so if the restriction is at the air filter or at the throttle plate it doesn't really matter unless you are running wide open throttle, personally I like the best filter I can afford as I like to keep as much dirt out of my engine as possible, so small holes and alot of area, I used to have a foam air filter but I sold that car and it was the best air filter in my mind.
Most people will say that they have good luck with warm air intakes, they work in theory and in practice, Honda used to have a warm air intake as part of their intake design on all of their cars, it would maintain a 100F air temp and you could tell when it was not working because your mileage would drop like a rock.
Old 09-01-2010, 12:56 AM   #4 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
depends on how you drive I mean I personally have picked up mileage by adding K&N filters running slightly lower weight oil and doing exhaust and running the cars on premium
also keeping tires aired up to max PSI actually helps more than i thought it would (that's a trick i learned from the guys on here) and i've actually seen a pretty good LRR tire for trucks there's a guy on base that has them I'll try to find the truck and let you know what they are They look similar to a michellin hydroedge
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 09-01-2010, 06:05 PM   #5 (permalink)
Most of the mods are doing well to increase your fuel economy by a few %. The really good ones can bump it by as much as 10%.
Changing your driving style can easily increase your fuel economy by 50%. As far as "low-hanging fruit", that is a really ripe one. Just slowing down to the speed limit and avoiding putting your foot to the floor can help quite a bit!
-soD
Old 09-04-2010, 09:37 PM   #6 (permalink)
Thanks for the info.. I intend to replace the filters with K&N eventually and the oil at the next oil change. What do you mean by "doing exhaust"?? And are you saying that I should spend more for premium gas to get better MPG??
As for the tire pressure, I check them regular once a week, but I set them to the door pressure .. not the side wall max pressure. I have been wondering about that pressure. Should I check the air pressure when the tire is hot or cold? Setting to max sidewall pressure will not change the ride much on my truck but a couple mpg would be nice if it works. I would love any recommendations for LRR tire for light truck. I have been contemplating using passenger tire also.
Don
Old 09-04-2010, 09:43 PM   #7 (permalink)
-soD
I am working to retrain how I drive but people don't like slow drivers .. gonna get a sign on my truck that says "HEAVY LOAD" so they stop honking at me
Curiously when I was actually HAULING what turned out to be 1290lbs of gravel for that 40miles of mostly highway it appears that I got better MPG than when no load. Man I wish I could afford to drop the coin for a SGII. Instant MPG would help a lot while trying to retrain.
Don
Old 09-04-2010, 09:52 PM   #8 (permalink)
Don
Actually i use K&N air filters haven't tried their oil filters but i've heard good things about them. Well with premium on a newer car i'd say try and use it a few tanks to see if it makes a difference on your vehicle mine are older so i adjusted the timing to run on premium and with the exhaust my thing with trucks is a flowmaster or flowsound (cause it's a direct flowmaster replica for only 40 bucks on ebay) with a turndown at the rear axle and on my car i just deleted the resonators with an x pipe and replaced the rear muffler. far as tire pressure check do it cold
If you're gonna use a passenger tire i'd say try the michellin hydroedges they're great tires with a pretty LRR plus they are a 90 thousand mile tire.
and with that truck i'm sure people are gonna suggest aeromods too
but it is true lots of the mileage increase you'll see is due to your driving habbits
Tank:
Old 09-04-2010, 10:41 PM   #9 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I am leery of any "magik" spark plug. The spark is always going to take the path of least resistance.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 09-05-2010, 01:25 AM   #10 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
What we are looking for in better fuel economy is the minimum amount of power, so what can you do to get less power? use a lower displacement engine! Better aerodynamics reduces the power needed to go at any given speed, all else being equel. I think wikipedia has some good articles on Internal combustion engines.
Heated Fuel bennelson EcoModding Central 81 03-10-2022 11:28 PM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Theory: not just disabled cylinders, but a power/compound cylinder engine mechman600 EcoModding Central 18 04-16-2010 07:02 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Alternator delete, other engine mods for city driving DoctorP82 EcoModding Central 6 10-29-2008 10:54 AM
