Originally Posted by Prophecy99
noob question whats EOC ![Embarrassment](/forum/images/smilies/redface.gif)
Welcome to the forum. No apologies necessary for being new, just a big welcome and all the help you can get.
Here's a couple resources to get you started:
Glossary: SVOBoy has prepared a thread that tries to capture most of the acronyms like EOC that you already ran into. There are so many that I sometimes forget what ones mean that I already looked up before. Anyway, go to the top of this page, and under the header that says ecomodder in the funky font you will see a row of links for different parts of the website (Home, Forum, Blog, ...). The furthest to the right is Glossary and it will take you to SVOBoy's thread which identifies most of them or at least the long form of the words.
Then if you go to the 100+ Hypermiling Tips and/or 65 Efficiency Mods you will also find many of them explained relatively simply.
Then if you still hunger for more information another good tool is the search which can be found below "Home" (below the row of links mentioned) on the far left near but not at the top.
Cheers.
