Old 03-23-2010, 01:13 PM   #11 (permalink)
BigWhiteWhale - '01 Ford F250 Lariat Crew Cab Superduty
According to my truck computer about +3-4mpg highway and +2mpg city. I have to go through my receipts from this trip and do some cipherin'. I have a scan guage but I was doing random/partial fills to take advantage of best fuel price (St Joseph, MO, walmart)
The Following User Says Thank You to Bajascoob For This Useful Post:
Plumbnman (05-12-2010)
Old 03-23-2010, 02:54 PM   #12 (permalink)
great #s Baja,
The Following User Says Thank You to stockrex For This Useful Post:
Bajascoob (05-28-2011)
Old 06-14-2010, 07:57 PM   #13 (permalink)
BB - '07 Dodge Ram 1500 SLT
90 day: 19.69 mpg (US)
Any new mileage data?
The Following User Says Thank You to mosby For This Useful Post:
Old 06-15-2010, 01:17 AM   #14 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
i like that you can see through it.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following User Says Thank You to IsaacCarlson For This Useful Post:
Old 06-17-2010, 11:49 PM   #15 (permalink)
I still haven't got a chance to get a good ABA. Between the scanguage and the truck computer it's 3 or more mpg on the HWY. I recently change the plastic material to "3M 2174W Outdoor Patio Door Insulator Kit with Tape Dispense" and welded the emt, removed the hose clamps. I was able to use only one box of the 3m stuff with some creative cutting. This stuff has no rip-stop but it is nearly invisible. Pictures to come.
Amazon.com: 3M 2174W Outdoor Patio Door Insulator Kit with Tape Dispense
Old 06-19-2010, 07:12 PM   #16 (permalink)
How well can you see through the new material? could you post a picture or two?
Thanks
Old 09-18-2010, 11:57 AM   #17 (permalink)
Light weigth aerocap
Here is the 3m version. it is perfectly clear. it lasted for a good while untill i hit it with my daughters scooter, unloading. it cut it. I taped it, which held for about 200miles.
Old 05-24-2011, 04:51 PM   #18 (permalink)
Found some non-3m film that is a bit thicker, and on sale (early spring clearance of winter stuff). I wasn't really happy with the bed mounts before so I redesigned them, for easier access/install/removal. I double nutted the bolts in the be rail, so the nut and bolt always stays, and I just have to put the top nut on to install. I welded hinges in place of the clamps. On the driver side I removed the hinge pins and replaced them with "hair pin" for quick tilt up access. The "sliding glass door" size isn't big enough so I seamed it with the included tape. Previously I left triangle seams, this time I'm living on the edge and went straight across the back, it's a bit cleaner this way.
ID:	8449   Click image for larger version
ID:	8450   Click image for larger version
ID:	8451   Click image for larger version
Old 05-25-2011, 09:42 AM   #19 (permalink)
Very Nice! So what are you MPG numbers up to now with the +3mpg?
My dad has an '02 F250 7.3 4wd and averages right at 20 mpg with a moderate "tow" tune adding ~75hp and 125 ft-lb torque...of course I couldn't get him to do this because no ATVs or goosnecks could go in the bed...lol
The Following User Says Thank You to md7989 For This Useful Post:
Old 05-25-2011, 11:15 AM   #20 (permalink)
went from 16 to 19 on the highway. I run grill inserts too, lund makes some for winter warm up that clip in, I leave them in all year, unless I'm towin across the desert, then I take two panels out. I reviewed the eff mods list again and I may make some more grill area adjustments.
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
4th brake light and Rear fog light. Sean T. Off-Topic Tech 10 11-27-2008 12:29 AM
