Old 01-08-2012, 06:31 PM   #1 (permalink)
First drawing of RIDE prototype vehicle
For your consideration. The drawing is 10 inches long, scale is 1/15th.
Length 12 feet 6 inches, width 5 feet. Should match the ideal shape almost perfectly. Sides will be vertical for the first 18 inches, then match the curvature of the drawing in the vertical.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
BamZipPow (01-08-2012), TEiN (01-12-2012)
Old 01-08-2012, 06:46 PM   #2 (permalink)
Very elegant, very simple. Looks great! what kind of engine?
Old 01-08-2012, 09:05 PM   #3 (permalink)
It is going to be a hydraulic hybrid, so the engine could be from a pressure washer.
The in wheel drive (rear wheel) is based on my US Patent #7677208. Using only the rear wheel on the first functional vehicle due to cost of scratch building the in wheel drive.
Front suspension is a ball joint late VW bug, late 60s to early 70s.
regards
Mech
Old 01-08-2012, 10:27 PM   #4 (permalink)
nice. why hydraulic?
Old 01-08-2012, 10:41 PM   #5 (permalink)
I guess the best answer is to prove the viability of my patented design. In essence a self hypermiling car. The drive allows for constant speeds while running on accumulator pressure alone, with the engine cycling on and off to replenish pressure in the accumulator. Deceleration forces also recharge the accumulator. What is achieved by expert hypermilers will now be incorporated into the basic design of the vehicle, automating what is now done by the driver without speed fluctuations normally associated with pulse and glide.
Fuel consuming engine on cycle percentage will depend on average demand, with the engine always running at peak efficiency.
regards
Mech
Old 01-08-2012, 11:22 PM   #6 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Why not a tandem design to reduce FA?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 01-08-2012, 11:41 PM   #7 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
regards
Mech
This patent?
Radial rotary engine with energy storage - United States Patent 7677208
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 01-08-2012, 11:52 PM   #8 (permalink)
Yes on the patent.
I prefer the side by side seating. The front axle is 60 inches wide, and everything seems to fit well together with some room for side protection.
The curves match the template perfectly for best aerodynamics, and the design of the VW axle gives you a decent amount of collision protection as well as the natural tendency of the trailing arms to deflect and offset impact to the side.
Overall length of just over 12 feet is all I need to package everything.
regards
Mech
Old 01-08-2012, 11:58 PM   #9 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Very cool. I think your concepts have much potential.
I'm not coasting, I'm shifting slowly.
Old 01-09-2012, 11:18 AM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
- So engine can run always at best point in BSFC map.
- You can drive steady speed and the engine can do the push and gliding. Pump the pressure when needed.
-You can do engine braking by capturing pressure when you are braking?
Sound clever system so far and the body looks very nice. Is this RIDE prototype system optimised for fuel economy or will you have how many "horsepower" and what is the top speed target?
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
