Old 09-23-2024, 12:47 PM   #221 (permalink)
A simple curved rather than straight extension.
Piotrsko (09-24-2024)
Old 09-24-2024, 09:54 AM   #222 (permalink)
Hmmm odd stuff happening with the tufts over and behind the rear wheel
Old 09-24-2024, 04:20 PM   #223 (permalink)
Tilted the floor
I dropped the leading edge of the foam floor 12" I will need to re-position the license plate. Only tested 10 miles. Might be an improvement.
ID:	35187   Click image for larger version
ID:	35188   Click image for larger version
ID:	35189   Click image for larger version
The Following 2 Users Say Thank You to JohnForde For This Useful Post:
aerohead (09-26-2024), freebeard (09-24-2024)
Old 09-25-2024, 09:41 PM   #224 (permalink)
After tilting the floor yesterday today I tightened the angle of the doors from 11 deg to 16 deg. The wake width is reduced from 48" to 34". Tomorrow I will cut away excess.
ID:	35191   Click image for larger version
aerohead (09-26-2024), BamZipPow (10-04-2024)
Old 09-26-2024, 01:33 AM   #225 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
11 degrees to 16 degrees is a big jump to make between tests.
The Following User Says Thank You to JSH For This Useful Post:
Old 09-26-2024, 11:22 AM   #226 (permalink)
' eleven -to- sixteen degrees '
I've mentioned that we have no direct analogue to Zevo, as related to reported test data.
P. T. Bearman did test a prismatic 'Windsor' saloon body square-back in 1984, which included 11-degrees, through 16-degrees rear slant ( roof only, no sides, nor 'diffuser' ) :
1) 'Any' slant created vortex-induced drag.
2) 'Profile drag' DID fall between, zero-degrees and 5-degrees, then rose again.
3) At 11-degrees, vortex-induced drag was Cd 0.01428
4) At 16-degree, vortex-induced drag had risen to Cd 0.04693 ( a 328% increase ).
5) For 'ALL' slant angles, drag increased.
6) The Ahmed body ( van ) 'square-back' experienced a drag minimum, with a rear slant angle of 9-degrees.
7) The soft-sided, 'Windsor body' square-back, achieved a drag minimum with a boat tail of 8-degrees, top and sides, with soft sides.
8) As slant angle increased to anything beyond 8-degrees, 3D trailing vortices pushed vortex-induced drag higher, increasing the total drag.
9) Revisiting Lawrence Livermore's research:
A) The #1 tail, with the 'LARGEST' wake, had lower drag than the two tails with the 'smallest' wakes.
B) The #2 tail, with the 2nd-largest wake, had the lowest-overall drag.
C) The tearing edge of the #2 tail would constitute the 'intercept' with the 'reversal point' of a 'streamlined' contour, at which flow would reattach, a captured-vortex would form, and a compromised pressure recovery would be realized, plus Hoerner's 'Angle of Flow', towards the wake would be 'optimum
;' and base pressure the highest.
Old 09-26-2024, 11:28 AM   #227 (permalink)
' wakes'
For both examples, the 'floor' does not extend the full length of the tail, allowing lower-pressure flow to adulterate what pressure recovery the top and sides are contributing?
Old 09-26-2024, 01:22 PM   #228 (permalink)
It was a simple revolting - now with bigger pie tabs!
Old 09-26-2024, 01:29 PM   #229 (permalink)
I can go back to 11 degrees. Simple repostioning. My enthusiasm for 16 degrees came from observing attached tufts.
I am going on a 1500 mile trip Oct 3-7 and should settle on a configuration.
aerohead (09-30-2024), BamZipPow (10-04-2024)
Old 09-26-2024, 01:39 PM   #230 (permalink)
Structurally, I need a square corner on top at about 44" behind the bumper. After that I could soften the corners by cutting up a 16" diameter concrete forming tube and using that 8" radius to coroplast the corner from sharp to rounded.
Could this be effective in addressing the vortices problem?
ID:	35195   Click image for larger version
Name:	WT 10' ext cone.jpg
The Following User Says Thank You to JohnForde For This Useful Post:
brightdrop, electric van, zevo
