Old 08-06-2020, 01:49 AM   #1 (permalink)
Flat tire kit instead of spare
I know there are compressed air sealants that are for this purpose. But the other day I plugged my tire at home really easily. I had a 3/16" screw to pull out.
Why not just carry those slim jims, simple tools, a bike pump(yes I've filled a car tire with one. Its a workout. Though if the bead is broke it wouldn't work) and also the rubber cement (I bought a can, shouldn't dry out nearly as fast). Isn't it better to plug the tire properly anyway?
Of course this doesn't help with a sidewall cut. But for the cost and weight savings it seems a lot better than having nothing.
Or should I just buy the flat fix can? What's the success rate with those?
For long trips I'd carry the spare.
Old 08-06-2020, 06:31 AM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Or just a plug kit and an electric inflater. While this is not the ideal way to repair a tire it can save your behind.
The Following User Says Thank You to nemo For This Useful Post:
wdb (08-08-2020)
Old 08-06-2020, 08:04 PM   #3 (permalink)
Reminds me of some women who told me they prefer to call their insurance instead of learning how to change a flat tyre. As long as there is no sidewall cut, maybe those quick sealing kits would still make more sense than waiting for someone else to change a tyre in rush hour, while a car stopped at some odd place because some selfish Ashley doesn't want to get her nail polish damaged might become a traffic nuisance for everyone else.
Old 08-07-2020, 01:12 AM   #4 (permalink)
90 day: 29.78 mpg (US)
It's been discussed before, but it's been a while. You're not going to see any improvement in fuel economy unless you're exclusively in stop and go traffic.
In my view, if you need the extra space, then ditch the spare tire. Otherwise, you might as well leave it in.
I consider tire plugs to be a permanent fix, and capable of fixing ~90% of tire "incidents". My preference is to plug even when a spare is available.
MeteorGray (08-07-2020)
Old 08-07-2020, 01:53 AM   #5 (permalink)
Carry a spare. I ran over some dropped metal on the highway and put a hole in the middle of the tire I could almost stick my pinky finger in. No plugging that.
I see people complaining all the time on the leaf forum that the leaf doesn't have a spare.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
MeteorGray (08-07-2020), Piotrsko (08-07-2020)
Old 08-07-2020, 03:40 AM   #6 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Also: Don't forget to check the tire pressure of the spare! When I did that it had 10PSI in it, it's supposed to be 60.
Old 08-07-2020, 10:26 AM   #7 (permalink)
Btdt also, ended up costing me a $ grand for 2 replacement rims and tire as the spare donut is useless, has to be swapped/ installed on the rear, limits you to 45 mph .......
Old 08-07-2020, 11:09 AM   #8 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Any benefit happens mostly at acceleration, when you have to haul your weight to speed. Stop/go traffic and pulse and glide. Steady cruising at speed technically must mean a benefit but you are not going to detect it and it will be very very small.
I hate the sealants in cans. Worse than useless. I love the plug kits. I still have a plugged tire in service 10s of thousands of miles later. Awesome.
redpoint5 (08-07-2020)
Old 08-07-2020, 11:40 AM   #9 (permalink)
I imagine they have a goo kit and not a plug kit. I'm not a fan of goo because it's less effective at plugging holes and ruins TPMS sensors. I've used goo successfully once, and unsuccessfully a couple times.
One time I drove home from hiking and the next day had a low tire. Figured it was a fairly minor leak since I was able to get home without issue. Wanted a quick fix so I put goo in the tire. Then I found the puncture, a 9mm bullet lodged in the tread. I pulled the bullet out and the goo puked onto my garage floor. Perhaps I'd be able to stuff a bunch of plugs into that hole, but that was one situation where having a full size spare was nice.
Old 08-07-2020, 11:48 AM   #10 (permalink)
I consider tire plugs to be permanent fixes too. Been using them for the past 50 years. I always have a 12vdc compressor along for the ride as part of my plug kit. I only use the spare tire or factory-supplied donut when the problem is a sidewall breach or serious tread separation.
The Following User Says Thank You to MeteorGray For This Useful Post:
